Touratech Zega - Pannier Locking Latch Plate and Bolt- missing - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Maintenance, Tech and Farkles.
Old 10-18-2012, 12:19 PM
shawnubis's Avatar
Default Touratech Zega - Pannier Locking Latch Plate and Bolt- missing
Does anyone know where I can get (outside of Touratech), or has any fabricated, the following item:
http://www.touratech-usa.com/media/J...?size=prodfull
(replacement part for TOURATECH pannier mounting hardware Part Number: 520-0035
Or, has anyone found an alternative to using the stock locking plates? I have everything but the one little plate.
Thanks in advance!
Old 11-05-2012, 03:22 PM
shawnubis's Avatar
Default Wow...93 views...no replies
(sigh) Guess It's Touratech.
If you think you don't need a helmet, you probably don't.
And remember kids, Safety Third!
Old 04-17-2013, 03:13 PM
Big_Willy_555's Avatar
Default Zega Pro missing parts
Dude,
I have lost the "L" bracket twice now due to them coming loose from vibration. I JUST ordered another replacement from Touratech today! I'm going to ditch the nylon acorn nuts, trim the threaded portion WAY down, and cross drill the stud to accept a standard hitch pin. Then I'm going to take the two hitch pins and fasten a light cable between them. This should prevent them from EVER coming off again, and still allow for easy removal.
Big Willy's Mo'cycle Repair
