Do I really need an X ring chain? - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Maintenance, Tech and Farkles.
  #11
Old 09-22-2012, 06:49 PM
aldntn's Avatar
I've had top notch performance from the EK Xring chain. Blair is great and his sprocket set is excellent.
09 DL650 ABS
MadStad + stock shield, JCW large topbox, Tuturo chain oiler, Heaterz grips, Suzuki hand guards, GIVI side guards, Aprilia Tuono mirrors, 36l Givi panniers, Richland Rick fork brace, Pipercross Air Filter
http://www.aldntn.bravejournal.com/
Old 09-22-2012, 11:38 PM
Ended up going through a vendor advertising on ebay. Went with a 118 RK x ring, clip master link, and 15/46 JT sprockets. Also got some PR3s coming.
Thanks for the advice!
Old 09-23-2012, 02:09 PM
RK is good.
Let us know if the clip type master link remains reliable for you.
The 46 tooth rear sprocket will give you a slightly higher rpm for the same travel speed vs. the stock 47. Not a big difference.
2007 DL650A Whee! (SV cam transplant)
Manage the unavoidable.
Avoid the unmanageable.
Old 09-24-2012, 12:02 AM
46 is a smaller rear sprocket, so wouldnt it bump my gearing up, resulting in a (slightly) lower cruising rpm?
(This is an awesome gearing calculator if you take enough time to figure it out lol):
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
