| Maintenance How-to WARNING! If you follow these posts and something goes wrong - Stromtroopers is not responsible for any damages, etc. You assume all risk. |
How do I adjust this?
ImageUploadedByMotorcycle1311379127.483618.jpg Peg lowering puts lever too low. Thanks!
2011 DL650 ABS |
| Sponsored Links | ||
Advertisement | ||
#2
And anyone have a link to the parts diagram for the rear brake lever? Searched the parts catalog and found nothing. Help!
2011 DL650 ABS |
#3
Take out #36 and pull #27 off #18. Put it back offset one spline clockwise. Loosen lock nuts #37 and #34(left hand thread). Rotate #29 to fine tune the position and tighten the lock nuts.
![]() The rear brake is not as adjustable. If you have the Richland Rick peg lowering kit, it will include a spacer. Otherwise, you will be forever pigeon toed and either have a too high pedal or have to do surgery on the master cylinder pushrod #5 in the last fiche. ![]()
#4
When I needed to changed mine as a result of my peg lowering kit, I put a mark on the shift mechanism so that I could return it to stock or know when I had moved it one spline. Simple and quick process as outlined by Pat. For the amount of adjustment I needed/wanted, in retrospect I did not need to move the mechanism one spline, there was enough adjustablity in the adjuster to work for me. I tried it both ways because it was such an easy and fast thing to do.
#5
Thanks, all. I was putting it back on with the elbow low and forward instead of high and back. Really don't feel any need for further adjustment.
Sent from my iPhone using Motorcycle
2011 DL650 ABS |
#6
The diagram and instructions are perfect. Thanks. Joe.
#7
just did a little shift lever adjustments myself - - the only thing i found tricky was keeping the whole linkage stable when trying to loosen/tighten the jamb nuts 34 & 37.
Used some needle-nose vise grips to grab onto linkage above top nut and below bottom nut. One have one pair of needle-nose vise gribs though; two would have made it easier . . . had to work the rubber housing out of the way a bit . . . |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
