TRE install on DL1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 06-17-2010, 02:29 PM Thread Starter
VBLA427's Avatar
....curious to know what has been other owners' results after installing a TRE on their DL1000?
marked improvement....or waste of $$$?
thanks
VBLA427 is offline
post #2 of 6 Old 06-17-2010, 06:46 PM
I installed one on my 2003 SV1000 naked. Same engine as the DL1000. The result was that it did run stronger in the lower gears, but the TRE mod makes the bike a little cold-blooded at startup. Probably not a good idea if you live up north.
If you go to the SV owners forum and do a search, they list instructions for doing the TRE mod using an inexpensive resistor from Radio Shack. I believe I paid about 6 bucks for a whole pack. It took my stepson about 10 minutes to do the install. Was if worth it? Yeah.
Good luck.
Givi crash guards, Suzuki handguards, Madstad bracket, Grip Puppies, mirror extensions, Suzuki tall touring seat, Dan Vessel skid plate and hiway pegs, Givi E21 side bags, Touratech side stand plate, tool tube, turn signal mod,
03 Honda VTX 1800C (Red)
taxbiker is offline
post #3 of 6 Old 06-17-2010, 06:58 PM
bwringer's Avatar
As I understand it, the Ivan's TRE lets through the proper neutral signal so there's no idle issue.
I built one, but I think my solder-fu was bad.
bwringer is offline
post #4 of 6 Old 06-18-2010, 09:39 AM
Chuck0334's Avatar
I have one on my 02 Vee and it lets me have all the RPM you want thru all the gears. I love it . I also have a 16 tooth counter shaft and my bike pulls like a freight train. Chuck
Chuck0334 is offline
post #5 of 6 Old 06-18-2010, 05:06 PM
Travman's Avatar
I have a GIpro w/ATRE on order and will provide some feedback when I install it next week.
All who wander are not lost!
2008 DL1000 - Silver - gone
2008 Suzuki Burgman 650 Exec - gone
2007 Suzuki Burgman 400 - gone
Travman is offline
post #6 of 6 Old 06-25-2010, 11:42 AM
Travman's Avatar
Did the GIpro install
I installed the GIpro w/ATRE this week. So as not to post it twice, here's the link to the thread with the write up.
http://www.stromtrooper.com/showthre...383#post573383
Travman is offline
Human Verification
