Installing 2" + brakeline for 2015 Vstrom 650 - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #11 of 14 Old 09-11-2016, 02:00 PM
Cal
Did you get this installed?
I bit the bullet and took off the rad. Made getting to the 10mm bolt super easy. I put off installing the line extension until I was ready to do a valve check where I would have the bike all apart. I also had the forks off to do a seal change.....seemed like the perfect time to do the brake line!
I can confirm the hard line compression fitting was very tight and required some effort to break it free.
Cal is online now
post #12 of 14 Old 01-04-2017, 07:27 AM
I installed mine in about 30 min.without removing any other part except old line.Now the bleeding was a little longer, but not bad with the banjo bleeder.
richlandrick likes this.
tco2612 is offline
post #13 of 14 Old 01-04-2017, 09:49 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
Thank you tco2612.
richlandrick is offline
post #14 of 14 Old 01-07-2017, 02:36 PM
I thought knucklehead was a Harley term only used on Harley Forums
tco2612 is offline
Human Verification
