How to change the stator on a DL1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 53 Old 06-03-2008, 05:34 PM Thread Starter
MZBuckeye's Avatar
Bike's battery won't charge? It might be your stator. First diagnose the charging system per the service manual, and if you determine your stator is bad, here's how you change it out:
1. Remove seat, left side panel under seat and plastic skid plate, disconnect battery and drain oil (not sure if you need to do this, but I did). I also had the tank raised because I changed the spark plugs:
2. Disconnect the two black connectors near the regulator/rectifier underneath the side panel, below the seat:
3. Snip the zip tie that holds the harness to the frame:
4. Remove all the bolts around the left side engine case and the clutch slave cylinder:
5. Remove the left side engine case and feed the connected wiring harness off the bike from behind the frame. You'll find the stator bolted to the back of the engine case with 6 allen head bolts. Remove them and remove the bad stator, and remove and discard the gasket between the engine and the engine case you removed:
1997 Kawasaki ZG1000 Concours, [COLOR="DarkGreen"]GREEN[/COLOR]
Old bikes:
2001 Kawasaki ZRX1200R, [COLOR="Lime"]GREEN[/COLOR], sold
2005 HD FXDCI, sold
2003 Yamaha FZ1, "Bee", sold
2005 Suzuki DL1000, Black, sold
2002 Yamaha FZ1, Silver, sold
1991 Kawasaki Ninja ZX-6D, sold
1982 Honda Sabre 750 V45, sold
MZBuckeye is offline
post #2 of 53 Old 06-03-2008, 05:41 PM Thread Starter
MZBuckeye's Avatar
Grab your new gasket and stator. I ordered mine from MR Cycles to the tune of about $225 shipped for both:
Old vs. New
Bolt the new stator in place, and press the rubber grommet into the slot in the engine case:
Replace the gasket, and bolt the engine case back into place:
Feed the wiring harness behind the frame and back to the regulator/rectifier. Connect the electrical connectors:
Zip tie the harness into place, bolt the clutch slave cylinder back into place, and replace the side panels and the seat:
Old bikes:
2005 HD FXDCI, sold
post #3 of 53 Old 06-03-2008, 05:44 PM Thread Starter
MZBuckeye's Avatar
That's it! Fill it up with oil, re-connect the battery and fire it up. Finally, for god sakes wash all the filth off that bike!!!
Questions?
Old bikes:
2005 HD FXDCI, sold
post #4 of 53 Old 06-03-2008, 06:38 PM
16171
Very nice Dan!!!
Good to see it back together!!!
post #5 of 53 Old 06-03-2008, 09:24 PM
FireDog45's Avatar
Did you consider the higher output stator that is out there and if you did why did you decide to go stock?
Nice write up, BTW!
Steve
09 GSA
Gone but not forgotten:
Blue 2002 Vee
08 KLR
02 ST1100
99 DR350
FireDog45 is offline
post #6 of 53 Old 06-03-2008, 10:36 PM Thread Starter
MZBuckeye's Avatar
I only found one other stator available, and it was an OEM replacement, nothing I found about it suggested that it was of higher power. I did read about one called Electrosport that was of higher power, but they quit making one for the 1000 due to fitment issues. I decided OEM was the way to go.
Old bikes:
2005 HD FXDCI, sold
post #7 of 53 Old 06-04-2008, 01:38 AM
FireDog45's Avatar
That's the one I was thinking about (couldn't remember the name) and I hadn't heard about the fitment issue. That kinda makes your decision a little easier...
Steve
09 GSA
Blue 2002 Vee
08 KLR
02 ST1100
99 DR350
post #8 of 53 Old 06-04-2008, 08:54 AM
Administrator
Great Job Dan....... what are the torque values for the bolts that mount the stator, and did you use any thread lock?
2015 DL650 XT "Drill"
post #9 of 53 Old 06-04-2008, 10:30 AM Thread Starter
MZBuckeye's Avatar
Um, good question. I'm not sure, so I just used a common sense amount of torque. They came out pretty easily, so the torque value is not too high, and there was no thread lock used from the factory so I didn't use any.
Old bikes:
2005 HD FXDCI, sold
post #10 of 53 Old 06-08-2008, 02:29 PM
Until we meet again
Dirt_Dad's Avatar
Great write up, Dan. Sorry you had to learn how to do this, but glad you shared the experience with us.
2012 XT1200Z Blue, 2015 XT1200 SE Red, 2012 Yamaha XT250, 2013 Suzuki DR650
Dirt_Dad is offline
Human Verification
