Battery Tender Jr for 28% Off - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > Platinum Supporting Vendors Section > KneeDraggers.com
Old 07-20-2012, 06:22 PM
KneeDraggers.com's Avatar
Stromtrooper.com Sponsor
Default Battery Tender Jr for 28% Off
The Battery Tender Junior is much more than a trickle charger. It has a brain. It's lightweight, compact, and fully automatic; very easy to use, especially in small spaces. It will keep your battery fully charged so that it is ready to go when you are!
  • Battery Tender makes is super easy to keep the battery in your motorcycle charged and ready to go with their Battery Tender Jr.
  • The Battery Tender Jr. is more then just a battery charger, it has a brain that knows how much is just right and keeps it there.
  • The compact design of the Battery Tender Jr. takes up little room and the quick disconnect makes for easy storage.
  • If the battery in your motorcycle is difficult to get to, Battery Tender has the answer with the quick disconnect and a 12 foot cord. Bolt on one side to the battery and leave it there for convenient use when you need it.
  • A complete 4-step charging program that includes initialization, bulk charge, absorption mode, and float mode will ensure the best maintenance for your motorcycle's battery.
  • The brain in the Battery Tender Jr. will automatically switch to float and maintenance voltage after fully charging the battery.
  • Battery Tender keeps you informed when the Jr. is in use with the solid state two color LED indicator.
  • Going a step further, the Battery Tender Jr. is also shock proof and has reverse polarity protection.
  • Battery Tender includes a 5 year warranty with the Battery Tender Jr.
Shop the Battery Tender Jr Battery Charger at KneeDraggers.com
