differennce between hot spark plug and cold spark plug - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Information Vault
Information Vault Forum to post all historical information relevant to V-Stroms. For example, tech reports, published magazine/online reviews, links, etc. Not a discussion forum
Old 11-17-2012, 09:48 PM
JRWalker's Avatar
Default differennce between hot spark plug and cold spark plug
A spark plug is said to be "hot" if it is a better heat insulator, keeping more heat in the tip of the spark plug. A spark plug is said to be "cold" if it can conduct more heat out of the spark plug tip and lower the tip's temperature. http://www.ngksparkplugs.ca/tech-info-spark-plugs.cfm
fuelly link: http://www.fuelly.com/driver/jbw/dl1000
Old 11-18-2012, 12:20 PM
Jarlaxle28's Avatar
And the bonus question is... How can you tell when your existing plug is too hot or too cold??
When you think of the long and gloomy history of man, you will find more hideous crimes have been committed in the name of obedience than have ever been committed in the name of rebellion.
- C. P. Snow
Old 11-18-2012, 12:34 PM
Moderator++
In a liquid cooled bike, heat range isn't as big a deal as on an air cooled bike. Liquid does a much better job of removing heat from the combustion chamber, allowing a wider heat range on plugs. That being said, too hot a plug will erode electrodes too fast. In extreme cases, it can cause hot spot detonation or even pre-ignition. Too cold a plug will foul as it won't burn off deposits properly.
Old 12-23-2012, 08:22 AM
Too hot a plug will show pitting on the ceramic central electrode and will be colored white-ish gray, too cold will burn sooty. The color to aim for is light tan/gray with the tip looking clean. Lots of color images available with a little searching. Look up NGK or Denso.
Saturn 5
