Poll regarding loose rotor magnets. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Information Vault
Information Vault Forum to post all historical information relevant to V-Stroms. For example, tech reports, published magazine/online reviews, links, etc. Not a discussion forum
View Poll Results: Select the proper option at the top of the if you have found loose alternator magnets
2002 DL1000 0 0%
2003 or 2004 DL1000 8 42.11%
2005 or 2006 DL1000 4 21.05%
2007 or 2008 DL1000 3 15.79%
2009 or later DL1000 0 0%
2004 or 2005 DL650 0 0%
2006 or 2007 DL650 2 10.53%
2008 or 2009 DL650 1 5.26%
2010 or later DL650 1 5.26%
Multiple Choice Poll. Voters: 19. You may not vote on this poll
Old 11-06-2011, 10:57 AM
Moderator++
Default Poll regarding loose rotor magnets.
There have been a number of reports of loose magnets on alternator rotors. This is an attempt to see how many and on what bikes. I screwed up the question in the box a bit. Just select all that apply. You can check more than one option if you had more than one occurrence.
Pharmguy didn't have a problem other than his kid playing on the computer.
Old 11-06-2011, 12:04 PM
Bahill's Avatar
Thanks Greywolf!
If I had known how to do a "poll" I would have already posted one.
I'll be curious to see how this turns out.
2012 Yamaha Super Tenere
Old 11-22-2011, 03:25 PM
Moderator++
Bump. There are a lot more than two.
Old 06-23-2012, 08:38 PM
D.T.'s Avatar
There have been a lot of K3 model SV 1000's that have had the magnets come loose. Some have used JB weld to put them back into place.
2005 Suzuki SV1000R
1985 Yamaha XT608N
2012 Suzuki DL650AL2, over 13,000 miles already!
Old 07-17-2012, 06:38 PM
'06 1K w/three shifted magnets, and bad stator and R&R @ 61,000 miles. Rounded up a magnifying glass to check close for chips tomorrow. If the magnets are intact I'll be researching the best glue options.
Old 07-18-2012, 01:46 PM
pso pso is offline
My wife has an 09 and I have an 08 both are Wee's. No problems with the magnets so far.I voted as one but there are two bikes.
Old 07-18-2012, 01:52 PM
Moderator++
'08 and later 650s won't have magnet problems. The rotor designed was changed in '08.
Old 08-06-2012, 07:03 PM
Hate posting on a pole thread, but it does bring it back to the top again! I used JB Weld to re-install my shifted magnets because it was good for 500 degrees F and was highly resistant to acids, fuel, and other chemicals. I resisted using too much force to remove the remaining magnets for fear of breaking them; but added a coating between them.
If you ever ran a magnet through the dirt when you were a kid you can guess what I'm going to say next. When you try to add the product between the magnets it will stand up like stubble on a three-day beard! However it does settle in as it hardens: I guess as the metal particles in the epoxy become magnetized.
What this does to the epoxy structurally I have no idea. It's held together for two days now, and should it let go in the next 40,000 miles I'll bring this pole to the top again!
Old 03-10-2013, 09:23 AM
Over the last couple of months, My '07 1000 stranded me three times with a dead battery.
The first time, I assumed it was a dead battery, since I didn't really remember how long ago I had bought it. Plus, I was itching for an excuse to try one of those lithium iron batteries.
I had ridden the bike to work. Took it for my customary hour-long joy ride at lunch, all with no indication of problem. When ready to go home, battery could not turn over the engine, nor could it even wag the instruments.
Had a guy jumpstart me, and rode it the 10 miles to home. Ordered a new battery and replaced it.
In the following weeks, the scenario repeated itself twice. It seemed very odd because once someone boost started me, I could just ride the bike home, let it sit for a week or longer, and it would still start up fine and strong. Then I could ride it to town, park it no longer than 10 minutes, come back to it and...dead again.
So I bought one of those portable boosters to carry with me in the top case while I read forum posts about similar problems. Figured the booster would at least get me home until I figured out what was going on. Had one opportunity to use it.
Took the magneto cover off yesterday and, sure enough, the six magnets were all abutted next to each other. None are broken. One is still attached.
So I will be adhering them back on today, using JB Weld. There's a quick-setting version which I think I will try. I made some little rubber spacers to ensure uniform spacing from the one that is still attached. I will clean everything spotless with laquer thinner and/or acetone. Then intend to glue them back in the original order and orientation one at a time.
I'm going to try to leave a "thick film" of the epoxy between them. Based on past experience with JB Weld, I'm pretty confident that should suffice to prevent their shifting.
Looking closely, on mine it seems that the original adhesive was fully spread on the mating surfaces of the magnets, and a single uniform bead about a quarter inch wide was run around the middle of the inside of the rotor to serve as a hedge against their shifting (which, obviously, didn't work).
I bought the bike from its original owner with about 8K miles on it. It now has less than 24K miles on it. I know it has never been run hot since I've had it, and very seriously doubt it ever was by the original owner. I don't abuse it at all; if anything, my riding style babies it.
I did, however, change to full synthetic oil at last oil change, just a little while prior to the first manifesation of the charging problem. That could, of course, be mere annecdotal coincidence. After the rework is fully set, I'll be refilling it with Mobile 1 synthetic; seriously doubt that JB Weld would be affected by it.
Am feeling pretty confident the fix will work and will last. Thankfully none of the magnets in my instance seem to be damaged at all. We'll see.
All of the magnets show a full thin coating of the original adhesive on their entire mating surfaces with no gaps or voids. All of the five loose ones came cleanly loose from the inner surface of the rotor. That suggests to me possibly inadequate cleaning of the rotor before adhesion of the magnets at the factory.
James
Old 03-10-2013, 09:27 AM
Moderator++
Use the regular JB-Weld. The quick stuff has a much lower temperature tolerance.
