| Information Vault Forum to post all historical information relevant to V-Stroms. For example, tech reports, published magazine/online reviews, links, etc. Not a discussion forum |
| View Poll Results: Please check as many answers as apply to you. | |||
| I had a charging system problem on a 2002 DL1000 |
3 | 0.78% |
| I had a charging system problem on a 2003 or later DL1000 |
31 | 8.01% |
| I had a charging system problem on a 2004-2007 DL650 |
13 | 3.36% |
| I had a charging system problem on a 2008 or later DL650 |
28 | 7.24% |
| I had no charging system problems on a 2002 DL1000 |
5 | 1.29% |
| I had no charging system problems on a 2003 or later DL1000 |
71 | 18.35% |
| I had no charging system problems on a 2004-2007 DL650 |
136 | 35.14% |
| I had no charging system problems on a 2008 or later DL650 |
117 | 30.23% |
| Multiple Choice Poll. Voters: 387. You may not vote on this poll | |||
Let's see if the bike's model or electrical output has any correlation and get an idea of how widespread the problem may be. If the problem was not with the stator, please post what it was.
| Sponsored Links | ||
Advertisement | ||
#2
Well, I think the data is in. 2008 and later have stator problems. Just kidding, I'm only the second vote
Aim High and Ride Wheelies. |
#3
It would be more useful if those who have had charging system problems also list their electrical accessories, particularly high-draw items like incandescent lighting and (regularly used) heated gear.
Mileage would probably be good too. I'm not sure it's meaningful to compare an '08 with 5000 miles to an '08 with 30k. Oh, and "had none" should be "have not yet had any".
![]() '08 Wee Last edited by dtalk; 07-26-2010 at 11:28 PM. |
#4
Hope I don't have to change my vote from - no problem.
Stock '07 DL650, 45k miles, original battery. Very few accessories. 1] 52w max heated vest usually run on low, rarely used. 2] GPS, less than 50% use. |
#5
My '08 is at nearly 28k miles, and has had no electrical problems so far.
The auxiliary lighting is all LED (and in fact I replaced the tail lamps with LEDs). I very occasionally use heated gloves, and frequently use the OEM heated grips. All other draw is very minimal (audio accessories and whatnot). I have had a Back-Off LED voltage indicator in the dashboard for most of the bike's life, so I will have early warning of problems. It nearly always shows full charge, even at idle, except occasionally when I first pull up to a stop, whereupon a quick blip of the throttle always brings it back. (This indicator showed me that the LED tail/brake lamps definitely made a worthwhile difference in draw at idle.)
![]() '08 Wee |
#6
I saw no good way of including mileage in the poll. Only ten questions are allowed. I doubt if a larger load would be a contributing factor. A smaller load generates more heat. It would be good if people reporting failures would include load and mileage as a reply though. "Had" is past tense. It is perfectly appropriate at the time of answering the question.
Pat- 2007 DL650A was ridden to all 48 contiguous states. 2012 DL650A is just getting started. Nicknames for posting ease on my part, Vee = all DL1000s. Wee = 2004-2011 DL650s. Glee = 2012+ DL650s Last edited by greywolf; 07-27-2010 at 01:23 AM. |
#7
![]() '08 Wee |
#8
The regulator/rectifier failed on my 09 DL1000 with only about 300 miles on it. Hoping it was just a fluke.....
#9
For what it is worth:
2009 DL650 ABS, 8500 miles 35W HID headlights 2x10W aux LED LED turn signals 4x 3W aux LED Admore topcase LED kit stock tail light Using heated gloves & 90W liner when its cold GPS Doran TPMS No problems yet.
2009 ABS DL650 |
#10
2003
Stator and R/R failure - replaced with Suzuki stator and aftermarket (electrosport) R/R Electrosport R/R started failing within a couple of months--intermittent discharges--kill the engine and restart and would work fine the rest of the day... then one day...didn't get better. Replaced with a Suzuki R/R--doing fine so far. I'd have to look at my log book for mileage. Loads? Nothing out of the ordinary. BTW--If you smell something like hot wiring--look into it sooner than later. Must have been the epoxy in the R/R. Perhaps if I looked into it sooner it would have saved the stator, perhaps the stator took the R/R--who knows? .
L2V -- she's a stocker! |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
