Where to put thermometer sensor - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Sponsored by:RevZilla
Old 12-11-2012, 05:12 PM
WEE RUNNER
Default Where to put thermometer sensor
I bought a digital thermometer from Cyclemax. The sensor has a 18" lead. I'm going to mount the unit near the speedo. Where's a good place for the sensor?
2013 Northeast V-Strom Rally!
'09 Wee Strom
'08 Triumph Tiger
Old 12-11-2012, 06:35 PM
V-Tom's Avatar
I don't know if you have enough lead but on my 2006 I mounted it under the fairing above the front tire. I drilled a small hole or two and used a zip-tie to secure it. This kept it out of sun and away from most of the heat of the engine.
..Tom
Road Toads Charter Member - 2006 V-Strom DL650: 202,000 km 125,500 miles, 2012 DL650 New March 2012 54,000 km
Why Cars don't see bikes (SMIDSY)
SMIDSY detailed report
Old 12-11-2012, 06:43 PM
scott1000's Avatar
ew ew I look foward to reading responses, I'm in the farklin mood
If you give a Moose a Muff..ler...
Its a Kid thing
Next time I'll put some effort into my username. This one sounds like a toilet Bowl cleaner or Treadmill, or..
Old 12-11-2012, 07:36 PM
WEE RUNNER
I guess the best thing is to mount it first.
'09 Wee Strom
'08 Triumph Tiger
Old 12-11-2012, 08:44 PM
I believe the sensor on my 2012 V strom is under the headlight area at the front of the fairing. That's where I would mount it.
Old 12-12-2012, 02:33 AM
Strange Dog's Avatar
I'm most interested in how you are going to mount the display? The only thing I can think of is double sided tape, but I am also not sure if the cheapo thermometers I got from eBay are going to withstand the sun.
Fuelly
I'm 40 years old going on 60. Actually I've been going on 60 since I was 20.
Old 12-12-2012, 04:27 AM
[IMG][/IMG]
Copy this guy and mount your temp display just above the clocks.
Old 12-12-2012, 05:24 AM
Finally a bike like Strom i could have as a concubine and my wife doesnt object!
Old 12-12-2012, 05:11 PM
WEE RUNNER
I'm going to mount it flush near the speedo. It comes with a clip to hold it snug. I use an old soldering iron to melt the plastic instead of using a Dremel.
'09 Wee Strom
'08 Triumph Tiger
Old 12-12-2012, 06:40 PM
V-Tom's Avatar
The only issue with there is that sun hitting it can give you a completely wrong reading. That's why I put mine under the cowling above the front wheel.. no sun heat there and normally nothing comes from the motor either.
..Tom
