Givi lights ! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Sponsored byRevZilla
Old 12-04-2012, 05:50 PM
Default Givi lights !
Hello there,I have an 03 DL 1000. Iam going to install a pair of Givi S310 Halogen lights,at 55 W per light.Is this not going to be to much of a draw on the charging system ?.I was planning on keeping them on all the time.
Next question ! LOL
Is there a special tool to break a tire off the rim, on the side of the road
Out in the middle of no were,just wondering just in case this ever came up .
Iam going next year with to friends,on a trip to the Trans Labrador Highway.And we will be taking a spare tube with us just in case,so I know a steel bar will work but was wondering if there was a special tool out there for the job!
All so how many watts is the charging system good for ?
Thanks.......Stan
Old 12-04-2012, 06:47 PM
Moderator++
Electrical Basic V-Strom Wiring 101
For bead breakers Google motorcycle tubeless tire bead breakers. I've done it by pushing two tire irons down about four inches apart with one hand and lifting another in the middle to get the bead off.
Old 12-04-2012, 09:40 PM
Stalky Tracker's Avatar
Motorcycle Consumer News ran a comparison of bead breakers back in 2010; http://www.mcnews.com/mcn/model_eval...ulyBdBrkrs.pdf
I have the Tryepliers and it works fairly well; at least in the garage. Never tried it on the road or out in the middle of no where.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Old 12-04-2012, 09:51 PM
Thanks for the help!
Old 12-04-2012, 10:02 PM
[quote=diggerc;881089]Hello there,I have an 03 DL 1000. Iam going to install a pair of Givi S310 Halogen lights,at 55 W per light.Is this not going to be to much of a draw on the charging system ?.I was planning on keeping them on all the time.
Next question ! LOL
I think 55 Watts is overkill and puts too much of a drain on your battery. You can use the lights but I would put in 35 Watt bulbs, available at any auto parts store. My battery would not start my bike this summer because of my 55 watt lights (2012 DL 650). Since then I have installed 35 watt HID headlights and a battery meter.
Old 12-04-2012, 11:43 PM
Thumbs up Hope this helps
Hi guys I know the post a long time back but he beat thing I found
To break the bead is the side stand. Problems
If you alone on the side of the road but when there two of you
Dead easy. Remove wheel. Lay it under your mates bike and put side stand
On the bead. Dead easy. Did it yesterday on the bush road to Kruger national
Park. Cheers from
Aftica
Old 12-05-2012, 05:59 AM
Thanks Phil 323,I was too thinking a long the same lines! 35w
Old 12-05-2012, 06:00 AM
Great idea Swazi,I never would have thought of that. Thanks
Old 12-05-2012, 08:49 AM
chicago's Avatar
Motion Pro - BeadPro Tire Bead Breaker and Lever Tool Set
13 DL650, 03 DR650, 95 DR350
Old 12-05-2012, 09:29 AM
Default Fitting extra spot lights.
I stopped today to fit a new set of spot / fog lamps. When looking under the dash and the lights there is the perfect spot to for them. I had to remove all the push gromit plugs and few holds to take of the side covers but then had full access to fit a nut and bolt thought the lower fairing and through where the 2 large plugs went. Again the first side took hour and a half. Second side 10 mins. But now they all fitted and next to fit all the wiring.
Did you decide to put completely seperat from all other lights. ,?
For some reason can't upload pictures.
Maybe facebook
