General V-Strom Discussion Talk about all things V-Strom![]() Sponsored byRevZilla |
#31
Actually, I already found those latches, and have welded them in.
![]() Mine will be quick detach, and the frames I'm building will have separate mounting points so that the main sections of the frames can also be detached. |
| Sponsored Links | ||
Advertisement | ||
#32
i'm using this rack kit: Moose Racing Expedition Luggage Rack System V-Strom DL650 2004-2011 - RevZilla so far very happy with the kit... where did you get your latches and how did you make sure they were keyed alike?
DL650K7 XL1200N (Sold) |
#33
#34
i ended up drilling mine most of the way out too and using a chisel and hammer to pop them loose...i have a couple of boo boos and was planning on using some j-b to clean it up as well ![]() i was going to trim my lip on both ends of the box and lock both of them so i could hinge open either side or still take the lid off completely...after a lot of debate with myself that's what i have decided to go with... i'm also integrating loops on the lids to tie stuff down to the boxes, and will most likely make sure the dry bag i buy is narrow enough! something i probably would have overlooked! and don't worry, i will be posting plenty of pictures when they are all done...i've been trying to take pictures along the way so i have progressive pictures...it will be awhile as i work on them in my spare time...but hopefully get them done soon!!
#35
I originally used "Loops" on the lids that I made from cabinet drawer handles found at Lowes for $0.99 each.........but later swapped them out for real "Footman Loops" for a lower profile. I can still feed my ROK straps thru the Footman's even tho it's a tight fit........haven't really had the need yet. But if I decide to mount maybe Wolfman Rollie bags atop the ammo cans, I'll have the loops there. Good luck on the "build-up".......can't wait to see them!
Current Rides: 2008 Yeller Wee + 2000 ZRX1100 2013 May Rally: http://2013easterngathering.weebly.com I'm so ugly I stuck my head out the window and got arrested for mooning. Apparel Security Cables... http://www.stromtrooper.com/group-bu...m-apparel.html |
#36
Looks fine to me!
#38
I also put 4 loops (1 each corner) on top of each lid for tie-down points. The tie loops used with a 12' cinch strap work great, I've hauled a baseball bat (home to NWPA from the factory in Louisville), a tent and collapsible lawn chair on a 700 mile trip, and a Remington 760 in a hard rifle case to the gunsmith (and back since he wasn't open that day). ... just something else to consider while you're at it with the ammo cans.
05 DL1000 - PC III, cheap top box, cee bailey 27", 20mm ammocans, scottoiler, Rick's fork brace & peg drop, 530 conversion, madstad bracket, darkside, Moose bars
#39
I've seen loops and eye bolts through the center of the latch for locking the lids on but I had two problems. One is that the pad locks will rattle around while riding.. Two is that when you unlock the lids you'll have loose locks you have to put somewhere and not forget. So for not much more money I just bought the keyed hasp locks and will take a little more installation work and will be cleaner in the end.
#40
2007 DL650 |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
