General V-Strom Discussion Talk about all things V-Strom![]() Sponsored by:RevZilla |
#11
place it beside a brand new sprocket, then take a look, if they look different and the chain is worn, then replace the sprockets too
hard to read a sprocket accurately unless ya got something to compare it too
RandyO IBA# 9560 07 Strom 1k (7x,xxx miles) 99 SV650 (135,006 miles) 82 XV920R A man with a gun is a citizen A man without a gun is a subject http://i427.photobucket.com/albums/p...dStatesMap.jpg |
| Sponsored Links | ||
Advertisement | ||
#12
That's the one you have to look at, my bet is if you have a good look at it you will see what a worn sprocket looks like. Your rear looks fine. I'm *reasonably* good with chain maintenance, and the front (stock) one was toast at about 15,000 miles (24,000 Km). Replaced it with a cheapy 16 (vs. 15) tooth to see if I like that better (I do). I will replace with quality chain and sprockets when they all wear out sometime next year. By the way I got rid of an annoying rattling noise when I replaced the front, but can't tell for sure if it was due to the change in ratio or because of the new sprocket with no wear. I think it's mostly due to the fact the old one was so worn.
Black 2009 V-Strom 650A ABS with: Stuff. Needs more stuff. |
#14
I wear front sprockets a lot sooner than rear fwiw, I recommend this front sprocket inspection port mod
#15
'09 VEE '07 SE UC '02 CR 250 |
#16
I always assumed that if the front was very bad off I'd get some tooth jumping especially at spirited acceleration so that would tell me that I need to work on it. But I'll probably look in there sooner rather than later just to be sure... |
#17
Theoretically on your bike, the front sprocket should see about 3x more wear than the rear. It does on mine.
#18
#19
You sprocket says you won't will the Powerball.
'06 DL 650 "Scarlett" Target fixator extraordinaire. Never underestimate the power of stupid people in large groups.” ― George Carlin Make the world safe for stupid people and you will end up with a world full of stupid people. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
