General V-Strom Discussion Talk about all things V-Strom![]() Sponsored byRevZilla |
#11
I have used spray paint with excellent results.
Works in any color.... |
| Sponsored Links | ||
Advertisement | ||
#12
I've used hair spray for years, with excellent results and not one slip in thousands of miles of horrible weather.
The secret is to get the cheapest stuff you can find. A big can of extra-extra-extra-super-super-hold-hair-helmet-bonder is about 79 cents. Maybe 99 cents in the big city. The more expensive hair sprays are easier to wash out at the end of the day, and contain additives to make them less damaging to hair. The cheap stuff is far less water soluble and lasts forever. Bad for hair, but great for grips. While we're on the subject of raiding the cosmetics section for the tool box, nail polish makes excellent marking paint for cam chains and sprockets and other operations where you need to distinctively mark something. Also less than a buck on sale, and it even comes with a built-in precision brush.
2002 Suzuki DL1000 V-Strom, Dark Metallic Space Blue 1983 Suzuki GS850G, Cosmic Blue 2005 KLR650, Aztec Red - Turd II, the ReTurdening |
#13
I used a dab of Locktite PM construction adhesive. My Oxfords were rotating on the bar when heated up. Mo Bettah now. I used just a dab. I may want to get them loose someday.
#14
Excellent feed back on the hairspray. The problem I have since I removed the oem grips is they just slip right back on with no tension. I probably streched them a little but I am afraid if any moistures gets in the hairspray will just release. For what its worth I think a will just smear a little silicone in there.
#15
I don't know it it applies in your case but if you have a loose fitting grip you can solve the problem by putting a very thin, barely overlapped wrap of electrical tape on the grip first. Then spray the inside of the grip with WD40 and slip it on. It has to then sit for 24 hours undisturbed and it should never move again.
For normal grips I've always used hairspray also.
DL650K8 Yellow |
#16
2012 DL1000 Adventure (Tinkerbell) PC-V, TRE, CR8EIX plugs, Madstad bracket, Madstad 22" shield, Fork brace, 17/43 gearing, Airhawks, Chinese mirrors, mirror extenders, RDL. |
#17
Just remembered one trick I used a long time ago. I have a long needle tip for my air gun and used compressed air to "fluff" the grip on. Just clean metal tube and a clean rubber grip. They went right on with a little pressure. They would come undone the same way but always held unless really disturbed.
#18
Keep the Aqua Net in the tool box to spray on chalk lines when marking a floor, keeps em from "disapearing". And of couse installing grips. Allways wired dirt bike grips though probably wasnt necesary. I use Bel-Ray waterproof bearing grease for lip gloss, gives a nice blue hue and keeps you from licking your lips.
Some people are like slinkies, not really good for much but they bring a smile to your face when you push them down a flight of stairs. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
