Did mechanic error cause my crash? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Sponsored byRevZilla
Old 11-26-2012, 01:33 PM
Default Did mechanic error cause my crash?
Last Friday I crashed my bike (K2). I smelled gas, then boom went down. When I caught up to the bike which was lying 50 feet away, gas was gushing out from under the tank. When I got it home the fuel line was off the intake and turning the key sent gas everywhere. I figure this caused my rear tire to lose traction around a turn.
Here's my question: As I lay in bed with road rash unable to sleep, I realized the last time I rode it was to go and have the chain and sprockets replaced. The mechanic yanked on the clutch cable quite a bit to get the sprocket cover back on. It snakes right up by the fuel line. Is it possible he could have pulled the fuel line loose and 100 miles later it came off?
PS these are not locking fuel lines, I redid them about 2,000 miles ago with hose and clamps. Haven't had any problems until now. I'm trying to see if I have any leg to stand on to approach the mechanic about fixing my bike. Needless to say, I had liability only.
Appreciate any opinions.
Road Rash
'02 1000, 35K
Old 11-26-2012, 01:39 PM
Moderator++
You replaced the locking fittings and had a problem as a result. This one is on you.
Old 11-26-2012, 01:48 PM
Is it possible he pulled the fuel line and it losened a little, sure, anything is possible, and that's going to be your problem. I don't see how you are going to prove your theory is the only possible scenerio that caused the fuel line to come off, and then on top of that carry it foward to be the proximate cause of the accident. Sorry to hear of your get off BTW.
Old 11-26-2012, 06:46 PM
Sorry about your accident
Heal up, move on you own this one, even if you don't this mod would so confuse the issue
Perhaps the dealer will "help" when you tell him your story and ask
Link Click Here >>> 2013 Northeast V-Strom Rally!
FILL OUT NEVA MEAL POLL If your attending
Also in events
8/2/2013
Old 11-26-2012, 06:59 PM
I think you're out of luck.
When you put the hose back on, how tight was it?
I'm with GW in thinking you were probably the guilty party more so than the mechanic, but there's really no way to know. But I can't imagine how much pulling he would have to do to pull off a hose with a properly tightened clamp. - Much less doing it in such a way that a failure wouldn't be immediately apparent.
Hope you heel up quickly.
2005 DL1000
Old 11-26-2012, 07:03 PM
scott1000's Avatar
Yeah that stinks you had an accident and messed up yoursekf & ride. However, I don't think you can argue its the dealer/mechanic's fault since the lines were altered. At least you'll heal in time and there's always other plenty of other parts/bikes in the sea..
If you give a Moose a Muff..ler...
Its a Kid thing
Next time I'll put some effort into my username. This one sounds like a toilet Bowl cleaner or Treadmill, or..
Old 11-26-2012, 07:05 PM
I tightened the crap out of the hose and it was fine for 2K miles. This happened on my first ride after they worked on it. I saw the guy yank on the clutch cable, rocking the bike, to get the sprocket cover back in. He finally did what he should have done and unbolted it and pulled it out. This cable runs around the fuel line and up to the lever.
Not asking for the world here, I'm already covering all my med bills. I just know they are part at fault or it wouldn't have come off.
'02 1000, 35K
Old 11-26-2012, 07:08 PM
tmcgee's Avatar
Whomever is at fault, you have no chance at proving anything. Heal up and move on.
Old 11-26-2012, 07:09 PM
Garbage Marc's Avatar
The clutch line runs along the frame and is held in place there so it shouldn't be anywhere near the fuel line sounds like your fix just gave out to me.
" Do not argue with an idiot. He will drag you down to his level and beat you with experience."
Present Rides
2006 V Strom
2012 Road Glide Ultra
Old 11-26-2012, 07:11 PM
About that...can you recommend an affordable route? So far it's left fairing, foot pedal, kickstand, rear pedal, handlebar, grip, clutch lever and something broke off the front axle.
'02 1000, 35K
Tags
clutch cable, fuel hose
