DL1000 Exhaust on a Wee? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Sponsored byRevZilla
Old 11-14-2012, 01:50 PM
CatfishRacing's Avatar
Default DL1000 Exhaust on a Wee?
Does anybody know if either (or both) Two Brothers DL1000 exhaust cans would fit a Wee?
Thanks.
Catfish
www.CatfishRacing.com
IBA #12835
AMA Lifer 462122
Old 11-14-2012, 02:46 PM
Moderator++
Thanks.
The systems are totally different. Each has their own aftermarket exhaust parts available.
Old 11-14-2012, 03:51 PM
I kinda figured they were different part numbers but I was more curious to know if either of the cans would fit.
I'm sure someone has tried it.
Catfish
IBA #12835
AMA Lifer 462122
Old 11-14-2012, 04:15 PM
Moderator++
The pipe diameters are different. The pipe placement is different. The cylinder heads are different sizes. Unless you weld stainless steel and can make tapered adapters and custom lengths, you're out of luck. If you are equipped to weld SS, the difference in flow characteristics would probably yield decreased performance.
Old 11-15-2012, 03:20 PM
Alrighty than.
Thanks for the info.
Catfish
IBA #12835
AMA Lifer 462122
