Completely sold on earplugs now - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Sponsored by:RevZilla
  #21
Old 11-25-2012, 12:25 AM
banditrider's Avatar
They are an "add-on". I've had them for a while - they came with a walkie-talkie based intercom that was a fixxer (the speakers weren't).
I also have tried a set of these (still got 'em): TORKX2 - Tork X2 Helmet Speakers. I went back to my old one's as the cord is thicker with a good waterproof plug whereas the Torkx seem to pick up some wind noise.
'08 Vee: Suzy luggage, Crash bars, Rad Guard & front mudguard extension, Zumo 550, Oxford Hot grips, Stebel, PC-8, 12v acc, Scott oiler & lube-tube, Remus Revolution Cans, Bark Busters.
'08 Concours 14: Rad guard, Stebel, Oxford Hot grips, Projekt D Screen, Hugger, GPS mount, helmet locks & front guard extension, Zumo 550, Stebel, Phil's rack & Givi V46, Sheepskin seat cover, Phillips Extreme vision +100 bulbs.
My Website
My Blog
Old 11-25-2012, 06:34 AM
Default Earplugs from EARMOULD
Just got some custom made plugs from EARMOULD in Adelaide. Fantastic! No more roll ups falling out of my ears and much quieter and more relaxing to ride with. Just be aware that for the first couple of days 110k/hr feels like 80k/hr. cost was $70 fitted on the spot and you walk out with them in 30 minutes. Can be fitted with earphones for iPod as well but I don't want that distraction when riding and certainly don't want to answer a phone. Highly recommend these plugs and this company.
Old 11-25-2012, 07:48 AM
Kurgan's Avatar
I've been a fairly regular wearer of ear plugs and normally use the orange or yellow foam cylinders. I've never had an issue with them coming out, etc. But I did drink the koolaid one year at the IMS show and had customer plugs made and they were a problem.
Once I put on my helmet, yawned, smiled or pretty much anything that involved facial muscles, the "seal" would break and I'd have all the noise back like an on/off switch from hell. Distracting, annoying and in to the garbage they went.
My foam plugs have never done that over the past dozen or so years I've used them.
Jim
2006 Gray Vstrom 1000
Old 11-25-2012, 09:26 AM
Moderator++
When doing custom ear molds, keep your mouth relaxed like you would normally have it while riding. Yawning or clenching your teeth can break the seal momentarily but it will return.
Old 11-25-2012, 01:08 PM
Possibly the material they used? My first pair were of a quite firm material and did not fit as well as my newer ones which are much softer. The newer ones stay in a lot better and are a lot more comfortable to wear for extended periods.
My Website
My Blog
Old 11-26-2012, 12:43 PM
weekend_warrior's Avatar
I use foam plugs. I also have a sena blue tooth with speakers. You can install the BT in any helment. Works well. I can knock the wind noise down and hear the speaks clear. I wish they could go just a tad louder, but I can still hear them. On the interstate its a bit hard, but on the back roads no issues as I try not to ride on the interstate.
07 V-strom 650 (gray)
06 KTM 450EXC (Plated)
94 DR350 (Old Faithful)
Old 11-26-2012, 09:18 PM
Lowell's Avatar
I have in helmet speakers for my communication gear and music and almost always wear foam ear plugs (whatever brand we have at work). I find it most important to wear them when listening to music because otherwise you are not only listening to road and wind noise but overcoming that with even louder music. I find the ear plugs cut out the road and wind noise easily and make the music much more enjoyable when I don't worry about destroying my hearing.
07 - DL650 dark red
