wiring help - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Sponsored byRevZilla
Old 11-10-2012, 06:37 PM
Default wiring help
I am going install a 12 volt rec, on my dash panel, going to run the wires from the battery, question I have is can I run my 2 wires off the rec for a volt meter or do I have to run 2 new wires from the battery for the volt meter. and maybe someone can give me a tip on how and what side do I run the wires to my dash panel, hope I don't have to remove the tank.
thanks
Chet
Old 11-10-2012, 10:06 PM
clovett's Avatar
digital voltmeter connections?
I found this one and a dozen others. I typed "install volt meter" in the Google custom search" box just below the tool bar on this site. I only say this so you can find the other ones for more pics etc.
2004 DL650 1994 CB1000 1992 DR350 2004 Z400
65 Norton 650 84 Honda XL200 75 Suzuki RM125
72 Yamaha 100 enduro 71 Honda CT90 68 Honda Z50A
Old 11-10-2012, 11:52 PM
You want to connect the voltmeter to a switched circuit so it isn't drawing power from the battery all the time. The heated grip connectors buried atop the radiator are one good choice. Be sure your 12v receptacle has a fuse in the positive wire, and run both positive and negative wires to the battery. Go ahead and take the tank off...it's good practice (and easier when it is low on gas).
2007 DL650A Whee! (SV cam transplant)
Manage the unavoidable.
Avoid the unmanageable.
