General V-Strom Discussion Talk about all things V-Strom![]() Sponsored byRevZilla |
#11
I have had these same issues recently. 2011 with hust over 10,000 miles. I hadn't seen this thread but I did get directed over to black lab and he was, as you all said, extremely helpful.
My bike had some Eastern Beaver extenders on it and the one that came out of the connector behind the radiator fried. I should have bought their relay switch to start with. I checked and cleaned the starter, hi-lo switch, connector behind the cowling, under the hood, and finally got to the connector behind the radiator. I think the real answer is it install the relays as the original system seems to create issues in 1 of the 3 places sooner or later.
Surf-or-Ski 2011 DL650 ABS 1981 Honda CX500c |
| Sponsored Links | ||
Advertisement | ||
#12
The real answer...
RichardD has part of it. Quote:
All this info was here, but got deleted. You won't find this on the other referenced site. When the problem came back, his solution was to (unnecessarily) bypass the switch altogether. |
#13
Bingo!
Can people here get tired of hearing "Thank-you's"? Found the little spring under the sliding contacts of the switch and it was indeed a bit stuck. Searched through multiple pens but no substitute springs on hand would fit, so satisfied myself with slightly bending the contacts up a bit and applying a bit of grease to aide movement. Removed the weatherstrip packing inserted previously and all is working again. Glad to know were to go if the problem crops up again and that it is fixable without purchasing a whole new assembly. Cheers All!
Rob in T.O. K7 DL650 ABS |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
