Turn Signal Mirrors? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Sponsored byRevZilla
Old 11-06-2012, 01:38 PM
Default Turn Signal Mirrors?
Wouldn't it be cool if someone made lighted turn signal mirrors for our motos, like new cars have? they could design them with LED wrap around lites that show turn blinks front, side, and rear! Heck, why not add brake lites in there also? how about a flexible stalk so they'd be less likely to break during laydowns? comments?
'09 Wee (silver) ABS
'05 Honda Big Ruckus 250 scooter
a 13 year old german shepard
one smokin hot,, soon X, WIFE! (hottybindu on youtube)
Old 11-06-2012, 02:14 PM
MNKid's Avatar
RideSafer.com has something like that, an add on, not a whole new mirror.
Jeff
2009 DL650A - Suzi Q
1983 GL1100i - sold
1973 CB500 Four - long gone
Old 11-06-2012, 02:24 PM
I have toyed with the idea............adding amber LED's to the front of the mirror plastic housing, as well as "inside" (behind) the mirror glass where the LED directs light out the back of the mirror. Once you get the mirror apart, you can carefully scratch away the mirror finish on the backside of the glass to allow the LED to shine thru. The mirror glass comes out after carefully soaking the mirror in boiling water.......enough to soften the gooey contact cement that holds the glass. I got as far as removing the glass and scribing a very small circle in the glass with an Exacto blade for the LED to shine thru. Never ordered any LED's.......and the project died on the vine. The mirror was a busted/scratched donor a member gave to me......
Some members (see Kenneth Moore's posts) have installed the amber LED's on the frontside of the Barkbuster Guards. His look "trick".......
Current Rides: 2008 Yeller Wee + 2000 ZRX1100
2013 May Rally: http://2013easterngathering.weebly.com
I'm so ugly I stuck my head out the window and got arrested for mooning.
Apparel Security Cables... http://www.stromtrooper.com/group-bu...m-apparel.html
Old 11-06-2012, 10:25 PM
Check out newer model GSXR mirrors. They have exactly that.
Old 11-08-2012, 02:13 PM
Default or?.....
how about little 2 inch led lite strips on front and mirror sides of each? does someone make such a thing?
Old 11-08-2012, 02:28 PM
I would go one step further than the mirrors and put an orange LED strip on the hand guards too.
Old 11-08-2012, 02:39 PM
chicago's Avatar
These could work....AdMore Lighting LED Light Kits
13 DL650, 03 DR650, 95 DR350
Old 11-08-2012, 02:41 PM
Kenneth Moore has "blazed a path" for us already...........
Hand-guard LED Turn and Marker Lamps with AdMore Lighting’s SuperBright LED Strip
Old 11-08-2012, 03:03 PM
Keith Falkner's Avatar
Default I like using individual LEDs.
I have six yellow LEDs in each handguard.
They were cheap, and easy to install. I did the math,
and put one 51-ohm resistor in series with three LEDs.
I used LePage's liquid tape to paint over the connections inside
the handguards, and the indicators have been reliable for 3 years.
I am sure lots of people have done similar work, and others will follow.
The only thing that makes my installation unusual is simply this:
I draw power from the REAR turn signals, by tapping into a cable that
is inside the plastic under the left side of the seat. My idea is this:
there are lots of reasons for taking off the front fairing, and any extra
wires up front may give rise to breakage by people not expecting the wires,
or extra charges for extra work undoing and redoing connections.
I think that additional signal lamps up front are not so important as
extra signal lamps in the rear, and that is one of my planned improvements.
Keith
Old 11-08-2012, 03:55 PM
fatalerror's Avatar
Forum Admin
Location: South West Florida, previously, South Africa.
I use Ducati Multistrada mirrors.
Tags
led auxilliary lights, lighting, mirrors
