Damned nut!!!! - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #11 of 16 Old 11-06-2012, 10:19 AM
Moderator++
The riser is mounted in rubber. Heat is not the way to go there. You can try two combination wrenches. Use the box end of one on the nut. Use the box end on the other over the open end of the first wrench. There are ways to get more leverage.
post #12 of 16 Old 11-06-2012, 05:04 PM Thread Starter
Ok, I did it. I t took me about three hours because everything went wrong, and I almost s...t myself cause of the pressure I had to put to unscrew the bolts, but I finished.
What do you think?
Was it worth it?
Memos is offline
post #13 of 16 Old 11-06-2012, 05:11 PM
jokermtb's Avatar
You put the bar on backwards!!!
Just kidding! Looks great.
jokermtb is offline
post #14 of 16 Old 11-06-2012, 05:42 PM
hunt1moore's Avatar
How did you do it?
PC-V, TRE, CR8EIX , ECM, K&N, RDL, PR4, PC-8, EB H4, WERKS, Madstad 22", 17/43 gearing, AdventureTech: Fork brace, shelf, mirror extenders, SpeedoDRD, wheel spacer, Head's-Up voltage monitor, Goldwing pegs, Sonic 1.1. Wolo Bad Boy.
hunt1moore is offline
post #15 of 16 Old 11-06-2012, 11:46 PM Thread Starter
I squeezed a 14 rench below the triple support and fastened the round end on the nut to stop it from spinning.Than,after taking the handlebar off,I tightened a breaker bar in one of the risers and unscrewd the riser instead of the bolt below.than the same with the other.It took a lot of strength,and I am a big man.It must have been tightened by a sasquatch.
Memos is offline
post #16 of 16 Old 11-07-2012, 09:21 PM
Cool,they look good. I have the same, but black with barkbusters on my Wee
rgp332 is offline
Human Verification
