Wrist problems? - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #21 of 26 Old 11-17-2012, 09:22 AM
nbsdave's Avatar
not uncommon to have wrist issues
thicker grips helped a lot for me-many use Grip Puppies, I wrapped grips with tennis racquet tape (the thick foam backed) and adjusted the bar angle 5 or 6 times till I got it right. Took the hex wrench, went on a ride and kept adjusting.
nbsdave is offline
post #22 of 26 Old 11-17-2012, 10:53 AM
Good points above about relaxing the grip and straightening the wrists.
Try this--
--Relax your face and neck. Let them soften and feel like they droop (but they don't, really.)
--Relax your shoulders and let them drop down & back.
--Ride with your spine straight and your trunk relaxed, knees just lightly against the tank, balls of the feet on the pegs and legs relaxed.
--Relax your arms and allow your elbows to drop down.
--Relax your fingers, hands, wrists. How loose of a grip can you hold on the grips and retain control (and control will be enhanced with a relaxed grip).
Next, re-relax. It is natural to tense up and not realize it. Consciously relax.
Try this for-free effort to relieve your wrists. If that doesn't work, then consider spending money for different bars or a medical evaluation of your wrists.
Many of us are comfortable telling the truth and uncomfortable lying.
An ordinary liar lies to gain an advantage.
A pathological liar knows that you know he's lying, and he lies to you anyway. Lying is comforting. Truth telling may be difficult and uncomfortable.
post #23 of 26 Old 11-17-2012, 12:00 PM
trobe's Avatar
Try this--
This^^^,+++ a quick stretch every time you stop, concentrate on your thumb, the downward motion of your wrist, and the upward motion of your wrist, 20 to 30 seconds on each hand/area at a time...while grasping your fingers at the top of the other hand slightly pull them backwards this will stretch your palm and wrist area too, repeat in reverse.
With your left arm at your side, tilt your head to the right side using the opposite hand placed over the top of your head slightly pulling toward the right side, extend your fingers on the hand at your side and slowly move your hand toward your back to increase the stretch, do each side (reversed hands/arms) 20/30 seconds, you might want to repeat a couple of times...try to remain relaxed and have your body in a straight stance, do not let your head droop, stand tall, or the stretch will not be as effective....Again, relax while stretching, this is key for your tendons and nerves to work properly, and for the blood to flow to the areas needed.
I hope this makes sense, and helps...
2014 Tiger Explorer XC
2014 Speed Triple
2003 SV1000S (track)
trobe is offline
post #24 of 26 Old 11-17-2012, 12:09 PM
trobe's Avatar
Now confess, how many did this while reading?...
Works and feels good, does it not?
2014 Speed Triple
trobe is offline
post #25 of 26 Old 11-17-2012, 02:19 PM
Originally Posted by Bamaboy View Post
You are on a long ride and your wrist starts hurting. What do you do?
Might check-out Moose ATV high bars. Different angle, cross-brace for added stability, inexpensive. Also went with Grip-Puppies.
06 DL1000
2007 Royal Star Tour Deluxe
Illinois is offline
post #26 of 26 Old 11-17-2012, 04:01 PM
Relaxing can do wonders for the veins and muscles. Veins in your hands must be "tired" after a long ride. You may change grips and find the one that suits you real fine. Might not be easy to determine exactly which grips work best but it can be done through trial and error. Hope it gets better soon.
TScott27 is offline
Human Verification
