General V-Strom Discussion Talk about all things V-Strom![]() Sponsored byRevZilla |
I clean the chain every 500 miles or so with kerosen and lube it with Dupont Teflon spray. I got 25,817 miles out of this chain. Guess it's time to replace it. Can't trust it now for any extended travel.
Regards; Aharbi |
| Sponsored Links | ||
Advertisement | ||
#2
DuPont chain saver is a dry wax formula that doesn't attract dirt. I wouldn't clean it off with kerosene so often and expose the bare metal. In fact, I wouldn't clean it at all but only wipe it after each application of lube, in effect, using the lube as a cleaner. 25,000 miles seems about average for 500 mile lubing. I'm trying chain lube after every gas stop now instead of every second one to see if that increases chain life.
#3
this is interesting.
I've been rather negligent with my chain maintenance. I dont clean it very often, and pretty much only remember to grease/wax it after long rides. I've been out in the rain, dirt etc. I just had a new tire put on the back, and looks like the chain is still good for another 5000 to 6000 km according to the mechanic. I just past 41 000 km on the bike (chain is original)
2008 Vstrom DL 1000 |
#4
A little surface rust on the side plates isn't a real big deal. Rust coming out from under the rollers indicates a dying chain. No need to clean the chain unless it has a lot of abrasive grit on it, and you probably won't get that with the DuPont stuff, anyway. Just a wipe with a dry cloth, if anything, should be sufficient unless there is goopy lube residue.
Rooster today Feather duster tomorrow |
#5
The problem with rust is it tends to grow. When it grows past the O/X-rings, it becomes a problem as the rings no longer seal. The usual first sign of a chain needing replacement for me is kinked links.
#6
If I'm not mistaken, that rusty stuff is the same material that you see on each end of railway cars.... metal to metal with no lubrication causes this.
I think that's why they are closing in new cars when they are railed. Of course I could be wayyyyyyyyy out in left field with this. Any railway men/ladies out there? |
#7
Now I get to do all the chain research all over again. Seems like it changes every two years. O-ring, X-ring, W-ring, DID, EK, RK, etc 525 vs 530.
Regards; Aharbi Last edited by aharbi; 10-11-2012 at 05:35 PM. Reason: added comment |
#8
I just put a Scottoiler on my Wee. Hope this will work out as well as everyone says! I had been using Dupont chainsaver, but I too saw some light rust starting after driving through 2 days of rain on a recent trip.
#9
I think that metal to metal stuff is called fretting and happens when the parts don't get lubed or washed clean of lube from too much diligence.
#10
I dutifully cleaned my chain with kerosene at 600mi and put on some name-brand chain lube. 600 miles later (1200mi total on the bike) I had rust already.
I commute, and the bike has seen it's share of rain - but I just can't believe how worthless that chain lube was for rust protection. On the plus side, being diligent about cleaning means I discovered it quickly. I'm going to just start bathing my chain in WD40 and not worry about it. A regular bath of WD40 can't be that much unlike a Scott oiler, can it? |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
