This piece fell off my bike. Do I need it? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Sponsored byRevZilla
Old 07-08-2012, 11:56 PM
CHINOTAKER's Avatar
Default This piece fell off my bike. Do I need it?
After installing rox risers in my baby this little piece of plastic fell off the handlebar area. I remember something about it when swapping the OG's handlebars to the ATV ones but I can't really remember
I was just wondering if I should worry or not?
put it back or not?
K9 ABS 650 BLACK
V-Strom: "The bulletproof machine"
http://v-strom123456789.blogspot.com/
Old 07-09-2012, 12:13 AM
chicago's Avatar
No idea, but if no one chimes in you might look at a parts diagram on a website like bike bandit and see what you can see.
13 DL650, 03 DR650, 95 DR350
Old 07-09-2012, 12:50 AM
Satch's Avatar
Stromtrooper.com Sponsor
Half of a throttle lock or other handlebar mounted accessory?
Old 07-09-2012, 12:56 AM
Flashmo's Avatar
I think that piece is from inside the throttle assembly, on the bottom half where the start button is located.
Old 07-09-2012, 02:29 AM
CHINOTAKER's Avatar
I think you guys are right I think I had to cut or file a piece of plastic to fit the ATV's
Do I really need this?
K9 ABS 650 BLACK
Old 07-09-2012, 02:30 AM
Yes, it's a spacer between the upper and lower half of the right-side handlebar assembly for the starter switch. Two bolts hold the lower half in place against the starter switch and this piece sits near the exit for the cabling. You should put it back along with the lower half!
