Cost for tire change and balancing - Page 4 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Sponsored byRevZilla
  #31
Old 11-18-2012, 02:17 AM
heffy's Avatar
You guys are lucky. I had the local dealership quote me a price of $500 to put a pair on Metzler Tourance EXPs on. When I told them I could get the tires for $275.00 on line, they told me it would be $150.00 to put them on. While that's cheaper than getting the tires from the dealer, I think it's a little excessive. I then called the Ducati dealership and they quoted me $400.00 for the same tires and mounting. I'm gonna invest in the No-Mar tire changer I think.
Requires ability to effectively deal with the morbid, the macabre, the repugnant, the abnormal, the morose, the psychotic, the neurotic and the otherwise unpleasant or unusual facets or results of human behavior.
2007 DL650 Blue (regretably gone)
2011 DL650A Black
Old 11-18-2012, 05:37 AM
Bead breaker out of 2x4's is $10
HF bead breaker is like $30
Motion pro Irons about $30 total get 3
Or bag of Zip ties
Compressor with tanks from 70 to 200 other uses
Tire lube $10
Pair of saw horses to balance $40 other uses
Link Click Here >>> 2013 Northeast V-Strom Rally!
FILL OUT NEVA MEAL POLL If your attending
Also in events
8/2/2013
Old 11-18-2012, 01:01 PM
LoneStrom's Avatar
I'm into my whole tire changing setup well under $100...
I have changed over 25 tires now so about $4 a tire and maybe 1/2 hour of my time!!.not to bad in my book!!.
1982 GS850..BLACK SUNSHINE,the tripod
2007 DL996AR..BRUTUS
Ah screw it,I'm goin ridin !!!!!!!!
Old 11-18-2012, 01:05 PM
Default tire changer
My Harbor Frieght said that changer is no longer available. Does anyone know of a changer that will work on mc tires in the same price range? Thanks, Dave
I live in my own little world, but it's OK, I am their KING.
Old 11-18-2012, 02:24 PM
LoneStrom's Avatar
I was at HF yesterday and didn't see the changer,so you maybe be right about it being gone!!.
Old 11-18-2012, 02:25 PM
LoneStrom's Avatar
You might also go online and try to contact HF corperate and see if any stores have it!!.
Old 11-18-2012, 03:06 PM
Originally Posted by heffy View Post
You guys are lucky. I'm gonna invest in the No-Mar tire changer I think.
After you've changed your first tire you will be amazed at how easy a tubeless tire is to change. I take the wheel off and pop the bead under the kick stand of my other bike. I have a round can with rubber tubing on the edge that I lay the wheel on and use tire tools to slowly work the bead off around the tire. I have been using dyna beads for a few years now but on a trip in Texas I had to change the tire on my DorsoDuro as it wore out too fast. I didn't balance it so I could head home. Since then I quit balancing tires at all, unless they later seem to need it. Nine of ten tires I put on don't need balancing, and if they do I just install dyna beads through the valve stem. I never go more than 85 or so mph and have not needed the tires balanced, but if I was still riding my GSXR 1000 I would want them balanced - albeit I would use dynabeads.
Old 11-18-2012, 05:52 PM
LoneStrom's Avatar
It takes me far longer to take the wheel off the bike than to change the tire!!.
Old 11-25-2012, 12:05 PM
Scootertrash in Paradise's Avatar
Nothing in the same price range, but we bought a Cycle Hill from No Mar and changed 22 tires last year.
And I'll start the controversy: we now use Dyna Beads with excellent success. Every bike is vibration free (we've gone as fast as 85mph on each) and we've had *zero* issues.
Old 11-25-2012, 12:36 PM
I won't pay for mount and balance at all.........That is just dumb!! Learn to do your own tires. I have a cheap harbor freight balance stand and wheel weights i get from my work as im a tire shop manager. If im at work with the bike and tire i will use my car and truck mag machine to effortlessly mount and dismount them. balancing is also very easy unless you are using tubes then it gets really tricky without a machine. The worst part is guessing how much weight to start out with and not to over do it. I changed 2 sets of tires on 2 bikes out in the pouring rain for 3 hours wearing an icon rain-suit. Just get some NICE tire spoons and some good tire lube. It's a lot of work doing it by hand but it is rewarding to spend the money on a mount and balance on the tools and gear to do the job yourself. Instead of some shops idiots who will scratch you wheel somewhere. I guarantee you would take better care of your own wheel and try not to damage it as best you could. Unless your just a klutzy idiot.
