General V-Strom Discussion Talk about all things V-Strom![]() Sponsored by:RevZilla |
#11
It would depend on the electrical load, the condition of the charging system and the quality of the connections. A marginal connection would fit the symptoms.
| Sponsored Links | ||
Advertisement | ||
#12
hmm..guess i'm going to have to check all the connectors in the light.
2006 Vstrom 650 1999 Triumph Trophy 1200 2012 Vstrom 650 (current) |
#13
I replaced the POS controller twice. The third time I replaced it with a DPDT 3 position toggle switch. I wired one side of the switch in parallel and the other in series with the center off. This yields a high and low heat setting that has worked out very well even running Grip Puppies.
EZ-RDR55 The opinions expressed herein are mine, and do not represent that of any other humanoid past, present or future on this or any other planet. '95 H-D FXDWG '06 Honda CRF250X '04 KTM 450EXC '97 Honda XR-600R '04 K1200LT (Sold) '07 K1200GT (Sold) '09 Wee-Strom DL-650ABS |
#14
^^^ this ^^^
2007 DL1000WF (with farkles )
#15
So with this system, it is actually really easy to tell where the problem is. When there is no heat, the controller-panel is lit up just like normal. So I know the DIN connector probably isn't the problem (assuming no pins are bent). And since it is both grips that are not heating, then it must be the little white connector from the controller-box to the pig-tail which goes to the two grips connectors. I'm assuming the wires aren't pushed in good, or come unseated with vibration inside the connector. Because all i have to do is reach down and jiggle it (probably not smart while riding, but i get cold! lol) and they start heating up. So, my question is, has anyone out there snipped off these connectors and used something else? I'd prefer not to permenantly attach the wires by crimping or soldering, because i like the thought of being able to unplug them (for whatever reason). Is there another set of connectors that are more reliable? thanks.
#16
not being a smart a$$ but do you see yourself needing to take heated grips off and on? why not solder? if you NEED to unplug them for some reason side cuts or a pocket knife work well.
Some people are like slinkies, not really good for much but they bring a smile to your face when you push them down a flight of stairs. |
#17
Anyways, that might end up being my solution, just hoping the find a more reliable plug i could use instead.
#18
Okay, so I found the problem. I pulled apart the cheap plastic main connector going to the controller box and then to the pigtails and I noticed some brown scarring on 1 of the pins. It looks like the flange opening had been shoved open a little bit, probably my fault, and it was likely causing arcing or loss of connection, and the arcing was likely creating a lot of heat. So, I wasn't able to get
Sent from my Galaxy Nexus using Motorcycle.com Free App
#20
07 DL1000, all farkled up |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
