High Front Fender - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 02-01-2010, 09:03 PM Thread Starter
goinssr's Avatar
High Front Fender
Been thinking for some time now about exploring the possibility of mounting a high front fender on my 06 Vee. I have seen many variations of this, some of which I really like and some that I think need to be put in the garage and left there. Has anyone explored the idea of using a newer model KLR650 front fender on the Strom? If not the entire fender then maybe just the front part as a beak. I haven't seen that combination and thought it may have some merit. What do ya think?
Stephen
2006 DL1000 (Mine)
2008 GL1800 (Hers..I just drive)
One Big Ass Mistake America
goinssr is offline
post #2 of 16 Old 02-02-2010, 05:26 AM
What Kinda Bike Is That?
Black Lab's Avatar
I am currently building a plug for a "high fender" at work during my breaktimes. Build the plug, build a mold from the plug, layup a fiberglass fender out of the mold.
I have not decided whether the fender will be mounted underneath or on top of the bottom forkclamp. I will post photographs when I am done.
B.
Black Lab is offline
post #3 of 16 Old 02-02-2010, 08:56 AM
Evolving Curmudgeon
kick's Avatar
I mounted a fixed beak below the headlites and fashioned a mini sub-fender that mounted to the bottom of the fork brace. When I rode on wet roads (after a rain but not raining) I got very wet from spray coming up through the fairing.
I took it all off and put the stock fender back on and now stay dry. My point is that a high fender needs to wrap around the back of the tire down to about the radiator to deflect water.
'07 WEE-HAAAA! Blue, loaded & sweet
I'll know where I'm supposed to be when I get there.
kick is offline
post #4 of 16 Old 02-02-2010, 09:36 AM Thread Starter
goinssr's Avatar
B.
I'll look foward to seeing what you came up with. Are you working on a full fender or a beak?
I can sure see that happening. Of those that I have looked at I like the looks of the full fender best. The beak sometimes just lokks like something is missing.
Stephen
2006 DL1000 (Mine)
goinssr is offline
post #5 of 16 Old 02-02-2010, 06:07 PM
Black Lab's Avatar
My hope and plan is to; mount a custom built fender/beak somewhere underneath or on top of the bottom forkclamp. As to the rear of the front tire, I will do something. I have not made up my mind as to whether I will make a rear fender portion attached at the points where the OEM fender is, (Like a BMW or KTM), or basically finding a piece of aluminum and welding it to the front of my skidplate.
At the same time that I am doing this, I am relocating my oil cooler. It is going to be mounted vertically, ( A Jagg 3090), on the left side of the forward cylinder head. By doing this, I can forget about it hanging out down below and I can block that area off with an aluminum plate.
All of my OEM fairings are being removed up front. I am installing a Buell Ulysses dual headlight and making my own minimal fairing.
There is another thread where I have posted some "inspirational" photos that I am drawing ideas from. I might be on the 3rd page of that thread.
Vstrom facelift - Single headlight
post #6 of 16 Old 02-02-2010, 06:08 PM
Black Lab's Avatar
There is a thread on the forum, "Mounting up a beak", that you may want to look for just for ideas.
post #7 of 16 Old 02-03-2010, 11:50 PM
Gravehunter's Avatar
DO IT!!!
If you don't use the whole thing... just remember you are leaving your rad and oil cooler open to rocks.. etc.. from the tire. You can always get a rad protector though to help reduce the chances of that though.
"I used to do drugs......... I still do...... But i used to too" .................... Mitch Hedberg... RIP
Gravehunter is offline
post #8 of 16 Old 02-04-2010, 10:17 AM Thread Starter
goinssr's Avatar
Originally Posted by Gravehunter View Post
DO IT!!!
I would prefer to use a full fender rather than he beak. What kind of fender did you use and where did you get your hi mount brake lines?
Stephen
2006 DL1000 (Mine)
goinssr is offline
post #9 of 16 Old 02-04-2010, 11:31 AM
asheville thumper's Avatar
I found this thread on ADV last night. Looks like a good compromise that would be cheap and effective unless your getting into some real sloppy stuff. Check it out, maybe it will be helpful.
http://www.advrider.com/forums/showthread.php?t=335665
[COLOR="Black"][/COLOR]Asheville Thumper-Western NC
[COLOR="Red"]2012 Tiger 1050[/COLOR]
[COLOR="DarkSlateGray"]2008 Wee-Strom[/COLOR]
[COLOR="DarkOliveGreen"]2010 Scrambler[/COLOR]
[COLOR="DarkOrange"]2010 KTM 690 Enduro R[/COLOR]
[SIZE="1"]`..`. ><((((((>
..`. ><((((((>[/SIZE]
asheville thumper is offline
post #10 of 16 Old 02-04-2010, 11:44 AM
Cat Herder
LowAndSilent's Avatar
First it's the high fender...then you end up doing what this guy did: Rebirth of a Wee Strom
When does it stop?!
'09 VStrom DL650A - Sold.
'04 Suzuki Burgman 400 - The wifes
'08 FJR1300AE - Miss Chievous.
WWGWD?
LowAndSilent is offline
Human Verification
