Tire Question: re-plug or replace - Page 4 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 19Likes
post #31 of 43 Old 02-16-2017, 07:53 PM
Macdoc's Avatar
Seriously small kit ...no reason not to carry
I'd be concerned about getting it into the tire with the small handle but as you say ...different system and I like the idea of a knot.
We carry the compressor that came with the mushroom plug kit but it's not that effective getting the tire up to 30+ lb. Any one recommend a better one?
Australia> 04 KLR650 93 ST1100 sold Canada > 10 Wee ABS 2009 CBF1000 09 Burgman Exec sold 10 NT700v sold
Travel photos> https://500px.com/macdoc/galleries
Macdoc is offline
post #32 of 43 Old 02-16-2017, 09:45 PM
Brojon's Avatar
Originally Posted by bwringer View Post
I carry a Nealey kit now -- it's basically a "sticky string" type of plug that's installed a little differently than most. They also are made with a slightly different compound that doesn't require glue. When you install it properly you end up with a knot on the inside of the tire that retains the plug. They're very versatile, and they even come in a nice little tube that tucks into your tool kit.
Nealey Tire Repair Kit - Repair Kits (the mini kit is perfect for motorcycles and cars)
I've never once had a problem with the Nealey plugs or with the many "sticky string" plugs I've installed.
I can say that I've only used them with radials and they've always worked great with many thousands on the tires.
That said I say use whatever you feel comfortable with since near as I can tell they all work great.
Checked my kit this afternoon and I need some new ones so I think I'll try those Nealey's out. Thanks for the link!
Question - how do they last long term under the seat? IOW I have these under my seat for 2 years and go to use one is it viable?
Spec likes this.
"The further a society drifts from truth, the more it will hate those who speak it."
George Orwell
2015 DL650
Brojon is offline
post #33 of 43 Old 02-16-2017, 09:49 PM
Brojon's Avatar
It used to be called the Sparrow Now it's called the Airman.
Small enough to tuck into that "shelf" under the seat where the brake light is, I've filled tires up to 70 psi (bicycle) and the gauge is reasonably accurate.
Cheap too.
George Orwell
2015 DL650
Brojon is offline
post #34 of 43 Old 02-16-2017, 10:58 PM
bolter 1100's Avatar
Originally Posted by Gert View Post
I agree with Bugzy. Had a plug fitted from inside, when I got a nail in a tire that was 890 km young. Rode at freeway speeds with that plugged tire, but checked tire pressure before each ride. At 10,649 km I decided to change the tire, as it started to loose pressure at the plug. Out of interest for yourself, compare the tire heat of the two wheels with your hand, after a ride. Lower pressure more heat vs correct pressure less heat.
I agree with Bugzy too. I was in the tire business for many years and our policy was to plug the tire to keep moisture from seeping into the hole and rusting the steel belts around the hole which could cause a tread separation over the long term. Then it was patched from the inside to keep the air in. Its certainly riskier to ride on a repaired motorcycle tire than a car tire for the reasons stated but I think a repair using the above method is perfectly acceptable.
Harry
bolter 1100 is offline
post #35 of 43 Old 02-16-2017, 11:11 PM
cyclopathic's Avatar
Airman C60A54 Tour Pump Air Compressor - Compact size with cigarette plug https://www.amazon.com/dp/B002UEKXOW/
Very good pump, accurate guage the only negative flimsy sigarette plug.
cyclopathic is offline
post #36 of 43 Old 02-16-2017, 11:43 PM
V-Tom's Avatar
The only "strings" I have seen and used don't require any additional glue.
Am I missing something?
..Tom
2006 DL650: 202,000 km 125,500 miles,
2012 DL650 139,500+ km, 86,700+ miles. Sold.
2015 DL1000 New July 2015 70,000+ km, 43,500+ miles.
SMIDSY detailed report.
V-Tom is online now
post #37 of 43 Old 02-16-2017, 11:53 PM
STCorndog's Avatar
..Tom
Belts and suspenders. My slow leaks have been reduced by glue and goo. Glue lubes them some too, so they slide in the correct depth and the tool comes out easier. I wait a little longer with the glue method before riding. Lunch or a quick nap.
STCorndog is offline
post #38 of 43 Old 02-17-2017, 12:20 AM
One thing no one's brought up -- it appears the bike may still wearing its original tires from 2012. In that case, the decision is easy -- use the puncture as the perfect excuse to replace those old nasty hardened five year old tires.
HEY! Check post #7. Sheesh.
MotoPumps. Picked up the Air Shot last year at Americade at a discount. Already used it a few times. Nicely impressed with it.
BigOgre is online now
post #39 of 43 Old 02-17-2017, 12:43 AM
vtwinpower's Avatar
I wouldn't hesitate to plug a motorcycle tire.
vtwinpower is online now
post #40 of 43 Old 02-17-2017, 09:43 AM
V-Tom's Avatar
One thing I learned was to make sure I give the insertion tool a good twist before pulling it out. It makes a little ball with the "string" in the inside of the tire and by doing that I have never had any leaks.
..Tom
Spec, Cryoman and cyclopathic like this.
V-Tom is online now
Human Verification
