.99 cruise control - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #11 of 21 Old 01-09-2017, 01:45 AM
the Cat o-ring is a little more than 99
about $3.50 iirc
IBA#9560
OydnaR is offline
post #12 of 21 Old 01-09-2017, 07:45 AM
about $3.50 iirc
Yeah, but it's YELLOW! And it's from Caterpillar...
2015 V-Strom 650XT ABS
1969 Triumph Bonneville
EddieFL is offline
post #13 of 21 Old 01-09-2017, 08:44 AM
Brojon's Avatar
Originally Posted by Rambouillet View Post
nice low tech approach - i have read about people using a rubber o-ring in there
Yeah - the big yellow honker off a Caterpillar. It does work *if* you have the proper end weight gap to roll it into.
Big B and EddieFL like this.
"The further a society drifts from truth, the more it will hate those who speak it."
George Orwell
2015 DL650
Brojon is offline
post #14 of 21 Old 01-09-2017, 08:47 AM
VSrider's Avatar
Necessity is the mother of invention.
VSrider is offline
post #15 of 21 Old 01-09-2017, 08:52 AM
Brojon's Avatar
Originally Posted by Satch View Post
I would *not* recommend this method of mounting as it's "always on" and no easy way to remove in motion.
Traditionally it's been used on the outer bar end weight and throttle - much like the Kaoko it provides a friction lock.
Unlike teh Kaoko it is always possible to roll back on the throttle without messing with anything.
So basically you let it ride on your bar end until you need to use it then you roll it on with your palm into the groove.
Just roll it out to stop using it. Unfortunately the Strom (well mine anyway) has a wide gap and the o-ring doesn't have enough to work with. The Kaoko actually has to provide a sleeve that it uses to apply pressure to the throttle.
I found a Kaoko cheap so I didn't McGuyver the o-ring of which I have a few.
My suggestion would be to cut a disc of plastic from a black Chinese takeout dish or large fender washer and put it between teh bar end and the throttle - it needs to be thick enough to provide a narrow groove for the o-ring to sit in and provide friction. Maybe even treat the disc with some of that spray on tool handle coating to increase the grip.
Make teh disc short enough where your palm can work against the o-ring to roll on and off.
George Orwell
2015 DL650
Brojon is offline
post #16 of 21 Old 01-09-2017, 09:00 AM
I found a solution when I took the end weight off my SV650 and put on bar end mirrors, a spacer made with 3/4" copper slip coupling filled with lead
Brojon likes this.
IBA#9560
OydnaR is offline
post #17 of 21 Old 01-09-2017, 07:46 PM
RCinNC's Avatar
This was my cheap-o solution; I made it out of sheet plastic after I saw a photo on line of a commercially made one. My cost was basically zip, since I had the plastic, screw and spring laying around from other projects. The tension was adjustable to get just the right friction on the grip.
I was still damn glad to get an actual cruise control on the Super Ten.
2014 Yamaha Super Tenere
2012 Suzuki DL650 (traded)
2004 HD Road King Custom (sold)
2000 Yamaha Road Star 1600 (traded)
1994 Yamaha Virago 1100 (traded)
1982 Honda V45 Sabre (traded)
1984 Kawasaki 440LTD (sold)
RCinNC is online now
post #18 of 21 Old 01-10-2017, 12:35 AM
StrommingAZ's Avatar
Nothing beats installing a Rostra, but it's not super easy. It IS super nice on long trips. Now I'm spoiled and can't think of not having a cruise control!! Tried a throttle lock- Vista, but now I'd hate to live without the rostra!
"No misfortune is so bad that whining about it won't make it worse!"
Jeffrey R Holland
StrommingAZ is offline
post #19 of 21 Old 01-11-2017, 12:45 AM
Letsgo2up's Avatar
Originally Posted by RCinNC View Post
I made it out of sheet plastic after I saw a photo on line of a commercially made one. .
This is so cool! Copied from a photo. Nice job, man.
'06 DL 1000
'06 Bonneville T100
'01 Honda VTR1000
'09 Kawasaki KLX250
Letsgo2up is offline
post #20 of 21 Old 01-11-2017, 01:26 AM
RCinNC's Avatar
Thanks a lot!
Human Verification
