The Big Oil Thread!!!! The Only Oil Thread!!!! - Page 196 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 180Likes
post #1951 of 1962 Old 11-26-2016, 01:26 PM
Highwayman2016's Avatar
The 5w just flows better at startup otherwise the protection should be the same.
2014 Wee Strom
Highwayman2016 is offline
post #1952 of 1962 Old 11-26-2016, 01:33 PM
Originally Posted by jimmyangst View Post
Well cr@p, I guess I better ask a question about oil filters here so I don't get yelled at. Apologies if this has been covered, or if there is some other thread I missed where it belongs, but I performed multiple searches and couldn't find anything relevant via "PC Racing", FLO filters, oil filters, reusable filters, stainless oil filters... it seems strange that nothing relevant came up in my 45 minutes of searching, but I am technologically challenged...
Anyone have experience with reusable oil filters? Specifically, I was reading about PC Racing "FLO oil filters", has a stainless, removable mesh screen filter inside the housing, cleanable and reusable. MCN and webbikeworld had fairly positive reviews.
Seeing as how the FLO filter is longer than stock, I'm curious whether they'd pose any problems with skidplates. And if anyone has used one for a long time, how well it held up (and cleaned up) over multiple oil changes.
Thanks for any info!
Jim B.
As was mentioned before, if you really want to know how this works do a test. Run an oil change interval with a regular filter and have the used oil analized, then an interval with the reuseable filter and the same oil and analize again. For even more results have fresh oil analized to see how much the oil breaks down under normal intervals and if you can run the oil longer. See the story on the 400,000 mile V S
trom.
2014 Wee Strom
post #1953 of 1962 Old 11-26-2016, 05:16 PM
From Motorcycle Oil Filters & Air Filters
There's a new type of filter being marketed, the "laser cut stainless steel filter," which we're told is "good for the life of your vehicle." These filters typically have 35-40 micron holes, which is really not acceptable. They typically have 30-40 square inches of filter material, which is really not acceptable. A paper based element is a 3 dimensional filter - when a particle gets stuck deep in the filter element, oil can still flow around it. The stainless steel elements are 2 dimensional - when a particle gets caught, one of the holes is clogged up.
I don't see how you can assure that all the holes get cleared out when you clean these. Certainly simply soaking the filter in kerosene is not going to release particles that have been jammed into a hole at 60psi. Blowing the filter out with air sounds good, but a motorcycle filter is too small to let an air hose inside.
These stainless steel filters cost about $120, about 25 times what I pay for a Pure One. Since I use my filters for about 8,000 miles, that means I have to go 200,000 miles to break even. I've never put more than 60,000 miles on a vehicle.
So reusable filtration is questionable at the very best. Cleaning it requires more mess and time. Cost is higher. Weak performance, added inconvenience, and higher cost. Why would anyone buy such a product?
dkayak1 is offline
post #1954 of 1962 Old 12-21-2016, 07:54 PM
Magnets for health
Always used a magnetic drain plug on motorcycles.
Recent reading advocate strong magnets and or magnets an the oil filter.
Probably not necessary "feel good" concept.
Fire away.
to ride or not to ride.. when in doubt gas it
rabbit is offline
post #1955 of 1962 Old 12-21-2016, 11:39 PM
NyMeTsFaN912's Avatar
Fire away.
Don't they all come with a magnetic drain plug?
-John
NyMeTsFaN912 is offline
post #1956 of 1962 Old 12-22-2016, 12:36 AM
Administrator
Yup Stroms have them....
2015 DL650 XT "Drill"
post #1957 of 1962 Old 12-30-2016, 04:05 PM
RazzleH's Avatar
Yes, and the result is like my fishing ... nothing caught. Seriously though, If there is engine or gear wear I'd rather catch the filings on the sump plug and know that it is happening than not. Changing the filter at every oil change just has to be the best insurance possible.
There is usually another way.
RazzleH is offline
post #1958 of 1962 Old 02-01-2017, 05:08 PM
Rick505's Avatar
Just received this link in an e-mail. Introducing the next evolution of hardworking protection from Shell Rotella.
To quote: Shell ROTELLA® is proud to announce a change to our hardworking portfolio of heavy duty diesel engine oils. We wanted to create the most technically advanced Shell ROTELLA® formulation ever. And we did. We also aimed to clearly organize our portfolio so you knew which oil to choose.
I'm a fan of T6 5W-40 in my DL650A. I've not consumed the information yet so wonder if the actual formulation will change or if it's mostly changing the bottle and label as mentioned on teh site.
Rick
Rick505 is offline
post #1959 of 1962 Old 02-14-2017, 05:22 PM
Car oil filter equivalents for DL 650
Is there a list somewhere in the forum for car oil filters that work on the DL 650 ? Thanks !
Scooter56 is offline
post #1960 of 1962 Old 02-14-2017, 06:48 PM
One such list is in this thread:
Alternate oil filters
-Gary
2014 V-Strom 1000 ABS
2013 V-Strom 650 ABS Adventure
2012 DR650SE
1982 Suzuki GS750
G-Dub is offline
Tags
10-40w , maintenance , oil
Human Verification
