650 vs 1000: the definitive thread - Page 97 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 29Likes
post #961 of 968 Old 12-25-2016, 12:53 PM
SECoda's Avatar
I think that is why I noticed the upgrade from the Wee2 to the Vee2 so significantly as well. I live right in the Ozark foothills so hills and twisty's are the norm. I have two sharp hair-pin turns on a steep hill just to get out of my neighborhood to the top of the ridge. If I lived where things are primarily flat and straight on paved roads the differences would be much less noticeable. Brakes, engine braking, shifting, use of throttle are noticeably different. It's actually more work on the 650. More low-end torque and better engine braking are very good things in the constant roller coaster environment. Most folks probably don't have to deal with that all of the time. Both are outstanding bikes.
DesertBike likes this.
2013 Honda PCX 150 (Candy Rose Red)
SECoda is online now
post #962 of 968 Old 12-26-2016, 12:59 AM
marcham's Avatar
I may be crazy but ever since I started riding at 17 I've always approached twisties with a pace where braking is not required. All the corners and straitaways flow seamlessly and if I feel the need to brake going into a corner I've misjudged the required pace. It requires a lot of discipline and awareness of the road ahead but over the course of several days it's a much less fatiguing way to ride. It also makes group rides much safer and more enjoyable.
Call me a numpty if you will but I can ride the same road at the same pace on a Shadow 750, cbr600 or V-Strom 650 and I'm quite content. So my quest is not one of power but of effortless riding balanced with comfort, range, performance and enjoyment. I've tried bigger bikes, I've tried smaller bikes. I found something just right in the 650.
Sent from my SM-T700 using Tapatalk
davidprej and Jergy52 like this.
2015 VSTROM 650 X ABS EXP
Previous rides: 2006 VT1100C2, 1999 SV650, 2002 KX125, 1987 GPZ305
marcham is online now
post #963 of 968 Old 12-26-2016, 01:07 AM
Radish's Avatar
No calling you a numpty here. I like to do a similar thing on my rides which is to use the gears to slow me down for corners and use the brakes as little as possible. It's not all about riding in the most aggressive way possible. Not to me anyway. Smooth and flowing is also fast if you do it right.
Coops.
SECoda likes this.
Some people are like clouds. When they go away it makes the day seem brighter.
2015 XT.
Radish is online now
post #964 of 968 Old 12-26-2016, 09:02 PM
Sgt Schultz's Avatar
The only real gripe concerns the fuel tank, a 20 plus litre tank be good. Why was it reduced for the 2015 model DL 650.
Would like to feel I could go 450 ks between stops.
I know nuffink, I see nuffink, It was not me, I was not here.
IBA #45920
FarRider #299
2015 Wee Strom "Piglet"
Givi crash bars, Barkbusters, Ravetech Bash plate, Ravetech Rad guard, Ravetech over dash Ram mount, Hyperlite flashing brake lights, Madstad bracket and screen, Augustus wind deflectors, Spot 3, UHF two way radio, Garmin Zumo GPS, Starcom intercom, Fuze block.
SW Motech Centre stand, Suzuki power outlet. Bike Alarm, Screaming Banshee horn, Led Flood lights, Tool tube, Andy Strapz Expedition soft panniers and frames.
Sgt Schultz is offline
post #965 of 968 Old 12-30-2016, 10:42 AM
SECoda's Avatar
On some of our inclines you would be at the bottom of a ravine without some form of braking unless you go 20 mph below the speed limit which is dangerous as well! Engine braking is still braking. The 650 is less effective in engine braking. Climbing twisties is where the 650 really disappoints. With two-up it is a lot worse. There just isn't any getting around the facts. Remember I owned both. For a while I switched back and forth to contrast them before I saw no reason to continue owning the 650. It only tops the 1000 in mileage and price but I paid basically the same for both (DL650A and the DL1000) as new but previous year models. There are too many improvements on the 1000 not to consider it seriously.
V-Tom, pvwheeler and Motobillb like this.
post #966 of 968 Old 01-01-2017, 10:17 AM
I guess you ride Harley speed, if you are not using brakes. That's an absurd idea for my pace.
RazzleH likes this.
2stroke is offline
post #967 of 968 Old 01-01-2017, 03:00 PM
Radish's Avatar
It has nothing to do with "speed'. More in how you set up for the corners. You can be doing 200mph and still not use the brakes if you start your speed reduction far enough away. It is not "racer' style riding but that does not mean that it is slow, merely a different technique and mindset.
Coops.
2015 XT.
post #968 of 968 Old 01-01-2017, 07:25 PM
I get it. When I took my racing license certification at racing school, they wouldn't let you use brakes for the first 30 laps. Many good lessons there. But if you want to carry any sort of decent pace, you need to be efficient on the brakes. Including trail braking.
Everyone rides at a different pace, I get it. I would be left for dead If I rode without using brakes with my buddies. (They are ex- number 1 plated road racers.)
2stroke is offline
Human Verification
