Loose-shaking fairing even possibly locking steering - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 06-18-2013, 11:11 AM Thread Starter
All the bolts and fasteners seem to be present, and snug. The fairing however, particularly the upper part that houses the instrument cluster, shakes a bit and is noisy (rattles) over bumps. The condition has worsened recently. Should I dismantle the assembly and install thin rubber shock mounts at critical points? The whole thing doesn't feel very solid-sort of a conglomeration of flimsy plastic pieces. '05 DL650.
phog is offline
post #2 of 15 Old 06-18-2013, 11:34 AM
Moderator++
Did you check the two bolts holding the fairing frame to the main frame?
post #3 of 15 Old 06-18-2013, 12:02 PM Thread Starter
Thanks Greywolf I didn't consider the possibility that the whole armature is loose. I'll check it out and see if I can access the bolts with the fairing still assembled.
phog is offline
post #4 of 15 Old 06-18-2013, 05:09 PM
What Kinda Bike Is That?
Black Lab's Avatar
Look here; right on front of the steering stem head. These two bolts have a history of backing themselves out. They should have threadlocker on them from the factory, but they don't.
Black Lab is offline
post #5 of 15 Old 06-19-2013, 12:59 PM Thread Starter
Thanks guys. The top one is present and fairly snug, the bottom one is missing. I'll pull the top one and match to another bolt.
phog is offline
post #6 of 15 Old 06-19-2013, 03:19 PM Thread Starter
BTW Greywolf, did you catch this recent story from Canada?
Motorcyclist takes photos of wolf chasing him on highway - Calgary - CBC News
phog is offline
post #7 of 15 Old 06-19-2013, 04:01 PM
Moderator++
I hadn't. I wish people would leave the wolves alone and they'll leave people alone.
post #8 of 15 Old 12-02-2013, 06:01 PM
Wantastrom's Avatar
Smile
Thanks Greywolf! This site is the best!
My son and I did the PineBarrens300 in NJ a few weeks ago. I was on the KLR and he rode the DL650. ( I couldn't pick up that vstrom in the deep sand )
At the end, he mentioned the front fairing and windshield seemed loose, moving a lot on the dirt roads and on bumps. Fine on smooth pavement.
Yesterday I went to fill up with gas, and sure enough I noticed the loose front fairing.
I searched this site last night, came to your picture (worth 2000 words) and checked it out today.
Sure enough, the top bolt was a bit loose, but the bottom one was more than 3/4 out! Blue loctite, and now they are in tight! Ill test ride tomorrow, but looks good!
I wish all my problems could be so easily solved by looking on Stromtrooper.com.
Wait….. maybe they can!
Thanks again!
2012 XT1200
2012 DR650
2007 DL650 (Madstad, Laminar Lip, OEM hand guards & centerstand, Bestem topcase, Fenda Extender, Givi Guards, Sheepskin seatpad, Superbrace, EnduroGuardian skid plate, TKC80's )
2003 Goldwing
2001 Polaris Sportsman 400 ATV
1993 KLR650
1993 Kawi KDX200
Wantastrom is offline
post #9 of 15 Old 12-03-2013, 07:51 AM
Jus had same thing happen last week. Bottom bolt gone and top hanging by a thread. Easy fix once you guess where to look. Scarey till then
SA OrangeV is offline
post #10 of 15 Old 08-08-2016, 07:17 PM
Moderator++
The two frame bolts are M8x1.25, 20mm long hardened bolts. Suzuki's gone wild of late with thread locker use but those bolts actually need it.
Sometimes, the first problem noticed is the steering won't move much past center on one side. That happens when a frame bolt comes loose and falls on the lower triple clamp.
Human Verification
