Stromtrooper.com
Go Back   Stromtrooper.com > V-Strom Forums > Maintenance, Tech and Farkles. > V-Strom Modifications and Performance
Thread Tools Display Modes
  #1
Old 10-07-2009, 06:36 PM
Switchfoot Switchfoot is offline
Stromtrooper Basic
Default Installing Acerbis Multi concept Handguards
Is there any mods that need to be done prior to installing? I am trying but running into problems with the throttle cables and the brake lever rubbing.
Any help would be greatly appreciated.
Thanks,
Doug
As you wander on through life, brother, whatever be your goal, keep your eye upon the donut and not upon the hole.
Old 10-07-2009, 07:44 PM
Rainier_Tom's Avatar
Rainier_Tom Rainier_Tom is offline
It's a Dorkie!
On my Vee I installed Acerbis MultiConcept handguards on Maier ATV Woods Pro aluminum barkbusters. No problems.
'06 KLR650 (Mr Twister)
'06 DL1000 V Strom (Missie Twistie)
If I only had a brain
Wear Hi-Vis and live!
Stir The Pot
Old 10-07-2009, 08:54 PM
Stromtrooper Basic
Default Some differences
Thanks for the pics. I see some differences, not sure how much the affect things.
You have a 1000, and looks like you extended your throttle cables, and your brackets are different than mine. The shell is the same.
I will try to use the pics and see if that helps.
Thanks again!
Old 10-08-2009, 05:12 PM
It's a Dorkie!
Throttle cables and hydraulic lines for the brake and clutch are all stock. I'm also using MSR Dominator ATV high bend aluminum bars.
Stir The Pot
Old 10-12-2009, 03:01 PM
longgreensilverado's Avatar
longgreensilverado longgreensilverado is offline
Stromtrooper Basic
look here for clamps that will help with a solution. i have the U-clamps
http://offroad.parts-unlimited.com/1...13?q=u%20clamp
I can't believe i forgot the trophy girls names.
2007 fast blue dl650
Old 10-12-2009, 05:09 PM
jddeering's Avatar
jddeering jddeering is offline
Stromtrooper Basic
I have the Acerbis Multi Concept on my 650 with the acerbis brackets. I had to move a few things around a bit, but did not cut or alter anything. I can send pics if youd like.
Old 10-14-2009, 10:02 PM
Stromtrooper Basic
Default Sent you a PM
You have pm.
Old 11-07-2009, 02:31 PM
Bullet Bullet is offline
Stromtrooper Basic
Hiya guys,
I'm new here and so is my DL1000 experiance. The previous owner had protaper bars (seven/eights) fitted along with Acerbis Multyconcept hand guards. It looks like in case of a fall the Acerbis mounts mounts could rotate taking out the Clutch/Break lines. This can also bee seen on th epic above.
Is there any experiance on that or am I just imagining BS.
thanks & Cheers
Old 11-07-2009, 04:49 PM
tmcgee's Avatar
tmcgee tmcgee is offline
[quote=Switchfoot;474318]Is there any mods that need to be done prior to installing? I am trying but running into problems with the throttle cables and the brake lever rubbing./QUOTE]
You might have to rotate/move cables and controls a bit to make everything fit.
-Tom (DL650-AK7) ('95 BMW K75)
Merci to Black Lab for the avatar shot!
Vstrom travels:
Forum Jump
Free hosting provided by i-Differ.net.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
