Stromtrooper.com
Go Back   Stromtrooper.com > V-Strom Forums > Maintenance, Tech and Farkles. > V-Strom Service and Maintenance Questions and Discussions
V-Strom Service and Maintenance Questions and Discussions Share your service and maintenance information-questions
Thread Tools Display Modes
  #11
Old 11-03-2009, 06:16 PM
greywolf greywolf is offline
Originally Posted by revrandy View Post
The actual light doesn't switch to hi-beam, just the light on the dash.
The high beam does go on too. As was mentioned, check the clutch lever and flash to pass switch and turn mount a little to clear if needed. Some people hit the switch with their hands and don't realize it.
Pat- The wolf with an E in grey.
2007 DL650 w/ABS AMA Life Member #755148
Old 11-03-2009, 08:22 PM
revrandy revrandy is offline
Stromtrooper Basic
The idea of hitting the pass switch makes sense if the actual hi-beam went on - it does not. The only thing that lights up is the dashboard indicator that my hi-beam is on.
Old 11-07-2009, 08:28 AM
Kcwiro Kcwiro is offline
Stromtrooper Basic
Question Question
This could be stupid but I am going to ask. Does your high beam work via the high beam switch? You might have a busted high beam filament and that is why you only get the indicator.
Old 11-07-2009, 11:24 AM
Stromtrooper Basic
Yes it did.
As for the repair, I took it to a Suzuki Place and the guy made a couple of adjustments and it was fixed in under 10 minutes. Not completely sure what he adjusted, think it was moving booth the clutch lever plus something else.
Forum Jump
Free hosting provided by i-Differ.net.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
