DL1000 Centerstand Replacement Parts Not ~? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Feedback to Suzuki
Feedback to Suzuki Only post information that you feel Suzuki would benefit from knowing. Not a "conversation" section
Old 03-01-2012, 01:31 AM
Default DL1000 Centerstand Replacement Parts Not ~?
The dealerships have no part number for any of the parts!?
The bolts/pivots/springs etc.
NOTHING appears on ANYTHING the dealers have !
AND no part number for the cooling system drain plug sealing/crush ring !?
Old 03-19-2012, 08:12 PM
Jstrom's Avatar
Question ?
Suzuki accessorie catalog part # 42100-06851 $269.95. Your dealer is obviously braindead. I'd look for another or buy one on-line.
K7 Wee, rebuilt like new and then some after collision with deer and mildly farkled.
Old 03-19-2012, 08:16 PM
Jstrom's Avatar
Default Whoops!
Sorry. Can't help if you're just looking for center stand parts. I thought you might be looking for the whole assembly which is probably the only way to get the parts. A bike like the Strom should come with a stand as original equipment.
Old 07-07-2012, 09:57 AM
Just Farkle It...
Been there, done that...prts are orderable, but typically long lead-time.
Old 07-08-2012, 04:44 PM
I've found the folks at cheap cycle parts . com are very helpful, anytime I've had a problem I call and they have the answer in a minute. I'm sure most of the OEM vendors are good. Good luck.
Old 04-20-2013, 07:01 PM
Kurgan's Avatar
You can get the springs you need from Suzuki, I just ordered and installed them, they're perfect. They're just not under the DL1000 parts list. Order the following part numbers:
09443-14059 and 09443-22013
Roughly $12.00 for both including tax at my local dealer.
Jim
2006 Gray Vstrom 1000
