Suzuki hard luggage keys - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Feedback to Suzuki
Feedback to Suzuki Only post information that you feel Suzuki would benefit from knowing. Not a "conversation" section
Old 01-17-2012, 04:45 PM
jaarch's Avatar
Default Suzuki hard luggage keys
I cannot for the life of me figure out why you would make the keys for your hardbags so thick at the hand hold. They are not computer chip keys so there is no why they can't be just flat metal keys. I prefer a nice small key ring when I ride and with the ignition, top case, and side case keys on a medium sized ring, you can barely get the thing in your pocket! I went to every key cutting place in my small town and no one carries a blank so I can have a standard metal key made. I ended up grinding the plastic down a bit to make them fit together better but they should not have been that way to begin with.
2011 ABS Wee A few farkles added so far....
U.S. Navy Senior Chief (Retired)
MSF Rider Coach
The greatest obstacle to learning anything is thinking you already know everything.
Old 01-17-2012, 07:21 PM
tiller4me's Avatar
And a word to the wise: DON'T EVER LOOSE THEM! I bought a set of oem hard bags, and the keys fell out of the box when it got damaged during shipping. I, and the dealer, went to great extremes trying to find the blanks, but to no avail. And one of my best friends is a licensed locksmith. The dealer finally ordered new locks from Suzuki to make it right.
79 GS1000S
97 TL1000S
2002 Concours
2005 DRZ400
2005 KDX220R
2007 DLK
2009 KLR650
Old 01-17-2012, 10:03 PM
Well since we're in bitch mode here, why can you not get side cases + a top case keyed the same!
Old 01-18-2012, 12:15 AM
tiller4me's Avatar
I guess I got lucky. The lock set Suzuki sent had 3 locks keyed alike. If I ever get an oem trunk I have a lock to match my side cases. But, only sent 2 keys.
79 GS1000S
97 TL1000S
2002 Concours
2005 DRZ400
2005 KDX220R
2007 DLK
2009 KLR650
Old 01-18-2012, 06:43 AM
Kip's Avatar
Kip Kip is offline
AMEN! Grrrrr!!!!
K6 DL1000 Silver Semi-Farkled
99 KLX 300R
02 Big Bear 400 4X4
89 TRX 250R
Old 04-01-2012, 10:00 PM
Default locks falling out
I just purchased a 2012 vstrom adventure and the locks on the hard cases need alittle attention. on a 100 mile ride today i lost a lock somewhere along the way. If i put in the spare I only will have one left. I noticed on the forums that others have had the same problem. Someone needs to look into why this is happening.
Respectfully, Doug
Old 04-05-2012, 07:51 PM
nuke's Avatar
big issues on the adventure cases locks. They are very difficult to use and many users have lost the locks. I will be requesting the dealer to replace these with the 1000km check and hopefully Suzuki has a better product available.
1972 CB350 (gold)
1983 CB750 Nighthawk (black)
2012 DL650/EXP (orange)
Old 04-10-2012, 11:34 PM
Default Locksmith changed mine, one key works now
I asked several locksmiths to make a SPARE key for the 'Soft-Italia' brand side cases, and a different SPARE key for the 'Soft-Italia' top case (3 piece luggage required TWO different keys). Finally, the last locksmith was able to help. He changed the top case internal lock, so now the side case key works the top case too! ONE key now works all 3 luggage boxes.
Now the Locksmith has put out a search for 'blanks' that can be ground to same shape as the original key, so I'll eventually have a spare key.
(Later posting) Scroll down to #10 for update.
Last edited by Montana73; 04-22-2012 at 12:05 AM. Reason: To help referencing for others
Old 04-16-2012, 03:21 PM
The lock issue on the Trax boxes comes from what appears to be an incorrect c clip that holds the cylinder to the housing. I also lost two locks and finally removed them all, replaced the c clips and then used a dab of rtv over them so they wont come apart again. The 2 spare locks are provided so that you can fit them in a Trax top box so of course when I ordered my top box I had to order another set of 6 locks so they would all be keyed alike. The locks have the same issues and they only come with two keys.
Old 04-18-2012, 09:14 PM
Default Key blanks for 'Soft-Italia' luggage
My locksmith (who did the above work) received a box of blanks that will be used for copying keys that WILL WORK for the OEM Suzuki hard luggage (Soft-Italia vintage). I submit the info of this blank for the good of the order:
SILCA Italy, GT 15 RAP
I had two spares made, and each opens all three luggage compartments flawlessly. If any OPs have a problem getting this blank from their local source/s, let me know and I'll send the locksmith's contact #s. I hope this is OK in Posting.
