Transferring accessories. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 04-21-2017, 04:22 AM Thread Starter
Still waiting on the new 650 Yellow XT I have ordered. Ive removed the genuine Suzuki crash bars and center stand of my 2015 Wee and also the Ventura pack rack. I am hoping the bars and center stand will fit the new model. They have changed the rear carrier but hopefully the mounting is still the same and the pack rack will also carry over.
kiwiRoscoe is offline
post #2 of 3 Old 04-21-2017, 06:43 AM
I think the rear will be like the Vee2.
With the new headlights they should use less power, especially if they are LED. I will assume the stator has the same output, you should have quite a bit more excess power to run lights and things.
Sent from my SCH-I545 using Tapatalk
No matter where you go, there you are.
frosty88 is offline
post #3 of 3 Old 04-21-2017, 07:04 AM
The headlights are standard halogen bulbs, not LED.
The rear pannier attachment points are now completely different and although they resemble the 1000 model require different suzuki part numbers. Equally Givi pannier racks for the current 1000 model will not work and Givi is developing new racks as is SW Motech.
johnfoxllb is offline
Human Verification
