Brake light now always on! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
DL650A - 2012+ DL 650 2012 +
post #1 of 5 Old 11-24-2012, 12:22 PM Thread Starter
Just discovered that my brake light is always on! Bike only a few months old!
Read a few threads indicating it might need adjustment near the foot brake side ... but i suspect it has something to do with the switch they replaced when the bike as new at the handlebar side (recall or something) ...
Anyone has any ideas
triumsg is offline
post #2 of 5 Old 11-24-2012, 12:56 PM
fortp's Avatar
First of all, press on your brakes levers, and listen for "clicking" sound to see if the switches change their state. The rear one is harder to hear, you will need a silence environment.
If one of them does not seem to "click" the problem probably come from that one.
If you get no good result with this, disconnect the front one (easier than the rear one) then check if the light is still ON.
If not, the problem is from this one.
If yes, the problem is from rear one.
Could be ajustment or defective switch but at least now you should know wich one.
Removing the front one is easy, just a srew under it. I think you need to remove the footpeg bracket to have access to the rear one. (But you should be able to turn the plastic ajustment nut with your fingers without remove the bracket.)
fortp is online now
post #3 of 5 Old 11-24-2012, 01:11 PM
Moderator++
It's almost always the adjustment on the rear brake switch.
post #4 of 5 Old 11-24-2012, 09:55 PM Thread Starter
Thanks guys .. i will go check it ... hope it saves me a trip to the dealer for work under warranty ...
triumsg is offline
post #5 of 5 Old 11-25-2012, 01:36 AM Thread Starter
You guys are great!
Removed front handlebar brake switch ... light still on.
Just a few turns on the rear adjuster .. and its perfect!
Just a tip ... that plastic nut is impossible to turn (see pic) .. i found it easier to place your finger on the nut to prevent it from moving and gently turn the plastic housing above it instead ...jus a few gentle turns and the brake light went off ...
Thanks again fortp & greywolf!
triumsg is offline
Human Verification
