Help - Strange engine clicking after 1st oil change - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
DL650A - 2012+ DL 650 2012 +
post #1 of 26 Old 11-21-2012, 04:32 PM Thread Starter
All,
At noon, I did my 1st oil change with 700 miles on the Odometer. I replaced the oil filter with OEM Suzuki filter (confirmed #'s were the same) and added 3 quarts of Mobil 1 Racing 4T 10w-40. I confirmed the oil level was near the full mark after starting the engine and filling the new filter with oil.
I went for a Tag-O-Rama ride (80 miles) and noticed a clicking noise at the traffic lights. After getting home, I shot this video. The clicking noise is apparently coming from the rear cylinder. It is a faint noise in the video, however louder in person and can be heard with the helmet on at normal helmet height.
Anybody have any ideas what the issue is?
The clicking stops when the rpms are raised. The clicking was not apparent prior to this oil change.
2012 V Storm - YouTube
mmonce is offline
post #2 of 26 Old 11-21-2012, 05:07 PM
henerythe8th's Avatar
You don't wear earplugs, do you?
2011 MG Stelvio
henerythe8th is offline
post #3 of 26 Old 11-21-2012, 05:19 PM
Moderator++
It's often reported. Chances are you just didn't notice it before.
post #4 of 26 Old 11-21-2012, 05:21 PM
If you change the oil filter, you need to run the engine a couple of minutes and recheck the oil. The oil filter holds a bit. Having said that, it would not be enough to cause any oil starvation. Really don't have any ideas at this point.
2009 DL650
Stromburger is offline
post #5 of 26 Old 11-21-2012, 05:33 PM Thread Starter
Nope, never wore ear plugs.
mmonce is offline
post #6 of 26 Old 11-21-2012, 05:34 PM Thread Starter
I did add more oil after starting.
mmonce is offline
post #7 of 26 Old 11-21-2012, 05:35 PM Thread Starter
Most of my miles are city miles with lots of traffic lights. The sound is very distinct and I think I would have heard of it earlier.
mmonce is offline
post #8 of 26 Old 11-21-2012, 05:37 PM Thread Starter
I do appreciate the feedback. I am a little concerned with it being a new bike and it being a cylinder noise. Only apparent in rear cylinder, front cylinder is smooth sounding.
mmonce is offline
post #9 of 26 Old 11-21-2012, 05:55 PM
slt824's Avatar
I would just take it back to the dealer. That's what warranty is for if you think there is a problem.
Good luck.
We interrupt this marriage to bring you the riding season.
2012 Wee - Fox Orange (Gord)
2011 Wee - Black (The Black Heathen) - Traded in
K7 Wee - Silver (Thunder) - Sold
slt824 is offline
post #10 of 26 Old 11-21-2012, 06:11 PM
Rick505's Avatar
Mine is a 2011 so different engine but try pulling in and holding the clutch and see if the noise changes/disappears?? Actually I had my 600 mile service done at the dealer and when completed made a road trip to of a few hundred miles over two days. I started hearing a knocking like noise after returning home and have had it since. Like others I've finally been able to ignore it....still don't like it but accept it as part of the bikes "personality". In any case, I've noticed, on my bike, it seems to be quieter when I pull in the clutch cable and hold it. In neutral on the center stand (or side stand I suppose), it's the loudest. However, like mentioned above, I'd take it in to the dealer if it really concerns you. Of course, when I made my next oil change myself I learned the dealer had the drain plug so loose I could unscrew it with my fingers. Last time I ever returned for service since I've not needed it in over 16000 miles with the help of folks here.
Good luck in any case.
Rick
PS - What's the status of your 1950 Ford truck. Yes, I checked out other YouTube videos while I was there.
Rick505 is offline
Human Verification
