Transfer of accessories 2009 to 2012 wee?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
DL650A - 2012+ DL 650 2012 +
post #1 of 7 Old 11-02-2012, 09:05 AM Thread Starter
I have the Richland Rick's footpeg lowering kit and Dan Vessel's elite DL650 highway pegs. If I purchase a 2012 DL 650 can I transfer these parts ??
"If you have to tell it to the judge, you've had too much fun."
seniorbiker is offline
post #2 of 7 Old 11-02-2012, 09:16 AM
Richland Ricks footpeg lowering kit from my '03 Vee went right on the 2012 Wee. The brake light switch connection might need a bit of adjusting but should be easy. I think the kit is the same for all V Stroms as far as the main part goes, the stuff to connect to the brake light switch is different on the Vee.
Don't know about the highway pegs.
Have questions about the clutch in your DL or SV 1000? E-mail Terry info@werksparts.com
realshelby is offline
post #3 of 7 Old 11-02-2012, 09:33 AM
HotPockets's Avatar
If you have the ones that mount over top the givi crash bars it should work seeing as the bars mount the same for all years.
'07 Yamaha Vstar 650 (sold)
'09 Honda CBR600RR (sold)
'12 WEEEEEEEstrom
'13 Yamaha FZ8
HotPockets is offline
post #4 of 7 Old 11-02-2012, 09:46 AM Thread Starter
Thanks, guys. Appreciate the quick response. I have the cruiser pegs that work without crashbars and mount back to the frame under the tank, with a bar across in front of the engine. I think these cruiser pegs might be a problem to transfer.
post #5 of 7 Old 11-02-2012, 09:51 AM
henerythe8th's Avatar
The primary frame is the same. Shouldn't be a problem unless there's an interference with the plastic.
2011 MG Stelvio
henerythe8th is offline
post #6 of 7 Old 11-02-2012, 09:59 AM
Moderator++
If you have this, I'm not seeing anything on the 2012 that will interfere as long as you don't have crash bars. Crash bars use the same mounts so it wouldn't work with them.
post #7 of 7 Old 11-03-2012, 03:02 PM Thread Starter
Thanks Henery the 8th and Greywolf.
Human Verification
