16 Tooth Countershaft fixes Speedometer! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
DL650A - 2012+ DL 650 2012 +
post #1 of 116 Old 06-30-2012, 09:29 AM Thread Starter
With the good midrange torque of the '12 Wee I though I might like a 16 tooth countershaft sprocket ( stock is 15t ). Around here I have to cruise at 70 mph and higher to keep from getting run over from behind and even out on the backroads it seemed the engine was a bit busy at 60-65 mph.
The new generation Wee has the speed sensor fixed to the countershaft like the Vee does. So, any changes in sprockets changes the speedometer reading at a given speed. Well, the 16 tooth is absolutely perfect in that respect! Riding with the GPS the speedometer is either EXACTLY what the GPS reads or sometimes 1 mph higher. I consider that about as good as it gets. I'll have to see how close the odometer is, but I would much prefer the speedometer accurate even if the odometer is slightly off.
At 70mph the tachometer is right at 5,025-5,050 rpm. The engine seems a lot more relaxed at even 60 mph and it still has plenty of roll-on power in 6th gear. Taking off in first gear is not much different, I was worried I might give up some there but not enough to matter. Gears actually seem better as there seems to be more "difference" between 2-3, 3-4, 4-5, etc. I didn't do this for fuel mileage or to make the bike last longer, just for more comfort.
Have questions about the clutch in your DL or SV 1000? E-mail Terry info@werksparts.com
realshelby is offline
post #2 of 116 Old 06-30-2012, 10:30 AM
Toytech's Avatar
Where did you source the countershaft sprocket? What brand?
I don't mind the going and I don't mind the stopping. I absolutely hate the stop and going.
Toytech is offline
post #3 of 116 Old 06-30-2012, 10:34 AM Thread Starter
I stopped by one of the local Cycle Gear stores. I think it was a Vortex brand or something like that. Part # 2910-16. The #2910 is what fits the bikes like the DL 650, GSXR 600, SV 650, etc. so they are easy to find about anywhere. GSXR's use the 16 tooth stock I think so that means everyone stocks them.
post #4 of 116 Old 06-30-2012, 11:14 AM
NWArkie's Avatar
We live in an amazing time. Thousands of songs and photos can be stored on a chip the size of your pinky nail. Our cell phones will answer any question we ask of them. Cars can now parallel park themselves. So Suzuki finally came out with a new 2012 'strom and still can't get the speedometer right?
NWArkie is offline
post #5 of 116 Old 06-30-2012, 11:22 AM Thread Starter
The speedometer would always read several mph faster than actual speed in normal traffic conditions.
Don't ask what the difference at around 100 mph on the GPS read on the speedometer..........allegedly and on a closed course with professional rider, etc.
post #6 of 116 Old 06-30-2012, 11:34 AM
NWArkie's Avatar
Sounds about the same as my 2005. It always reads 10% high. An indicated 55mph is really 50, and 110 is really 100. Is it about the same with the 2012?
NWArkie is offline
post #7 of 116 Old 06-30-2012, 11:38 AM
tmcgee's Avatar
Thanks, RS. This is what I was talking about in my "bike seems tight" thread from yesterday. So you too notice a diff from the earlier bike, yes?
tmcgee is offline
post #8 of 116 Old 06-30-2012, 11:58 AM Thread Starter
Our '04 has the pipe drilled out and the extra noise from the cam/clutch area made that bike seem about as happy at 6000 rpm as 5000. Noises were about the same. But the new Wee II is much quieter and when running over 5000 rpm seemed "busy". Probably because the noise seemed to increase? Maybe that is what you mean by tight.
I am sure it would run at 5500 rpms for days on end, I just wondered if the 16 tooth sprocket would make it feel better and it did.
post #9 of 116 Old 06-30-2012, 12:02 PM
tmcgee's Avatar
I don't think it's the noise diff, though they are different. Will give the gixxer sprocket a try. Cheap experiment.
tmcgee is offline
post #10 of 116 Old 06-30-2012, 02:14 PM
D.T.'s Avatar
Is the chain long enough so you don't have to add a link? This would shorten up the wheelbase a bit too. How about a Sunstar part number? I found it, it's 40416 for $22 bucks. I'm gunna go get one.
I will try this here pretty soon too. Hell, I may just run to Bob's Cycle supply this afternoon and get one! I assume the cs sprocket is put on with that nasty orange loctite Suzuki uses??
2005 Suzuki SV1000R, 1985 Yamaha XT608N, 2012 Suzuki DL650AL2, over 25,000 miles already!
D.T. is offline
Tags
countersprocket , speedometer
Human Verification
