Lowering the Strom - Page 5 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
DL650A - 2012+ DL 650 2012 +
 1Likes
post #41 of 58 Old 11-26-2012, 08:12 AM
I actually made my own lowering links out of 1/4" thick steel bar stock. I didn't have the time to make the fancy "dogbone" shape so they're just straight on the sides, but functional:
I went with 150mm spacing on the holes to give me slightly over 1" drop. Then I lowered the front by 3/4". So far after a few hundred miles of local riding, it handles great!
I may make some new links out of 6061 aluminum or the like, if the steel ones start rusting badly.
Love the way this bike handles.
Deano
dlare is offline
post #42 of 58 Old 11-26-2012, 09:10 AM
I forgot to mention that I also notched the sidestand to make it swing a little farther forward, effectively shortening it a bit and allowing the bike to lean further. This also reduces the tendency for the bike to roll off the stand if you park on a slight downhill.
I notched the sidestand instead of the stop, because it's easier to replace or fix than the stop...if I ever decide to go back.
Deano
dlare is offline
post #43 of 58 Old 11-26-2012, 10:22 PM
Originally Posted by Big B View Post
29/30 inch inseam the bike doesnt need to be lowered.
It needs to be lowered if the rider does not feel confident at the stock height, no matter what the inseam. BTW, what do u base this hard and fast rule on? Personally, I don't know why Suzuki has the Glee with so much ride height when they know 90% will never see a spec of dirt. I'd like to lower mine as well but I'm a firm believer in keeping the factory height unless there are mitigating circumstances justifying lowering the bike. Handling will be compromised somewhat whenever the height is changed. If I had 2" shorter legs, I would definitely want the bike lowered. I have a Russell seat and that made it more difficult for me to paddle the bike around and I have a 32" inseam. But not enough to change the ride height. I agree that the Glee ride height looks good with the longer travel suspension. Try a KTM Adventure for a scenic view.
phil323 is offline
post #44 of 58 Old 04-13-2013, 04:11 PM
Lowered my 2012 650 ABS
I made a post last year about this, and am just following up.
Mods to date:
1) Lowered front end 1 inch (by raising fork tubes)
2) Lowered rear end 1 inch (by using Soupy's Perf. adjustable dogbones)
3) Installed adjustable aluminum kickstand from Soupy's
4) Installed Factory Suzukit "low" seat
5) Using the cheap Tusk handlebar risers (I think they are 20mm versions).
6) Installed a Hepco-Becker center stand that I had modified by having about 7/8 inch cut off the bottom. I works, but it is still a challenge for me to get the bike hoisted up on the stand. (I may have ruined the geometry of the stand !!). I am going to try to raise the stand another .25 inch by re-drilling the mounting bolt-holes, or possibly by having slots milled into the current holes to allow a range of adjustment of perhaps about .375 inch.
My inseam: about 29.5 inches, and I am 5'8" in height, about 154 lbs.
Overall impression thus far: I can place my feet FLAT on the pavement IF I have thick soled boots on. Handling, IMHO, is not significantly affected for my riding style (fairly conservative, sedate paved road-riding, and NO offroad activity. I am 60 yrs. old, so have not "pushed" the envelope). The low seat is NOT as comfortable as the stock one for me, and I may try reinstalling and putting the low seat on eBay. I ALSO plan to
1) Install an extended brake line (already purchased)
2) Install extended electrical handlebar wiring harnesses for BOTH sides
3) Install yet more set-back for the handlebar using the 2" rotating Rox risers.
I plan to make a video of all of this and put in on Youtube hopefully sometime in May-June of 2013.
I love the bike, but also am keen on the new 2014 Honda 700 with the 28 inch seat height, designed just for guys like me. If that Honda would have been in the showroom last summer, I would have most likely bought it instead of the V-strom (no diss, intended, simply reality for me).
freyguy17 is offline
post #45 of 58 Old 06-29-2014, 06:08 AM
removing padding
Greetings strommer guys, has anyone tried removing seat padding to lower rider insem?
beemboy is offline
post #46 of 58 Old 08-11-2014, 11:43 AM
kilby's Avatar
Just installed a Corbin "low" seat which is comfortable but the width of the seat has me back on "tippy toes" again. 63 years old with 30" inseam. Would these kits remedy my situation? The older I get the shorter I get and the bikes all seem to get taller! First bike was a 1956 Triumph Trophy, it appears that the new Triumphs are still good for inseam challenged individuals.
If you don't start, you will always be late.
kilby is offline
post #47 of 58 Old 08-11-2014, 05:25 PM
chrisbre's Avatar
Certainly the 1 1/4" rear lowering links and pushing the form tubes up has made my 2012 650 so much easier around town and when stopping on shopping road sides for my ?31" inseam.
The stock seat needs help on day long rides - so I use an air seat pad on those occasional times - and put up with the extra height issue then.
chrisbre is offline
post #48 of 58 Old 12-28-2014, 01:27 AM
Texan's Avatar
Great info in this thread!
I removed the rubber blocks from underneath the stock seat and that helped quite a bit. Almost there so I just ordered the 3/4" Kouba links and I hope that does the trick.
5'8" 29" inseam. Perhaps I should have gotten the 1 1/8" but didn't want to be too low, if that's even possible.
2013 Suzuki DL650
2016 Suzuki GSX-S 1000F
All Gear All Year!
Texan is offline
post #49 of 58 Old 12-28-2014, 06:17 AM
I'm 5'7"1/2 ----- 5' 8" foot on a bragging day 28 " inseam , , sorta gorrilla like , I struggled , so i took of the seat lugs ,, no different , because the camper of the road is generally more ,,, so i bought the lower seat ,, helped a lot , but give me a sore ass , on anything over 100 klm or and hour riding .
Got me some lowering links from Richland , bike was perfect , lowered it through the triple tree at the front , and never noticed any difference in handling , if there is a diff i don't think the average rider is going to push the bike enough to know . .
I got sick of the lower seat , because i was /am enjoying riding it so much its now become my first bike instead of 2 nd bike so the sore ass got on my nerves , i put the original seat back on and alls good now , i am used to it and the height is all good .
Only problem i had was the centre stand , not being used to it and not adjusting it ,, i was not careful enough putting it down on 3 occasions , thank god for the engine gaurds , they do work .
I will not adjust the stand , because i'm used to it and more careful now . . The centre stand is not a problem , because thats all about technique anyway
coneye is offline
post #50 of 58 Old 01-14-2015, 11:40 PM
Sgt Schultz's Avatar
Hi, first real post here. Am about to get the 2015 650 V Strom, sometime in Feb.
Have ordered the lower seat, about 29 inch inseam, 5'7", wear thicker sole boots and am used to handling the Concours,(Kawasaki 1000 GTR).
Do not require to flat foot, am experienced enough handling the height and top heavy weight of the GTR.
May just ride the bike for a while to get used to height and handling, but am still thinking about putting on lowering links.
Would I need to lower, and will the lowereing kits such as Soupys fit the new model?
Cheers
Sgt Schultz from Australia.
Sgt Schultz is offline
Human Verification
