Performance Mods... - Page 5 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
DL650A - 2012+ DL 650 2012 +
 3Likes
post #41 of 92 Old 11-30-2012, 02:10 PM Thread Starter
D.T.'s Avatar
Okay, go for a ride dammit is the general concensus.
Got the shims where I want them and motor all back together, ran it again to check for leaks and it's all good. I'll go for a ride tomorrow afternoon with a seat of the pants dyno report.
2005 Suzuki SV1000R, 1985 Yamaha XT608N, 2012 Suzuki DL650AL2, over 25,000 miles already!
D.T. is offline
post #42 of 92 Old 11-30-2012, 02:11 PM
Stromtrooper.com Sponsor
SV Racing Parts's Avatar
Thumbs up
I am sure you will be very happy,
Blair
SV Racing Parts is offline
post #43 of 92 Old 12-03-2012, 06:52 PM Thread Starter
D.T.'s Avatar
Ride report from yesterday: It was really cold when I started, in the upper 30's. Motor ran just as it did with the stock cams. Seat of the pants dyno says it has a bit more torque, maybe 2-3 hp like others have said. I noticed a bit of clicking above 7000 rpm in the first 40 miles or so. But it seemed to dissapear after around 75 miles. I got in about 100. It burns richer due to the temps and the more black color in the exhaust tip.
Looking around I see that the new 650 uses the same rotor as the earlier models, BUT the Gladius uses a different rotor/flywheel. Lighter I assume. Looks like buying a Gladius motor would be the way to go.
I'd say if you can get a good deal on the cams it's worth it. So far so good. Not sure if I will put the pistons in this winter or not.
Box of fun parts!
D.T. is offline
post #44 of 92 Old 04-16-2013, 02:02 PM Thread Starter
D.T.'s Avatar
I found a Gladius rotor on fleabay for $75 and it will be here on Thursday.
I have the stator cover off and bolt removed from the rotor on the L2 now. I'm not 100% the gladius rotor will work yet. Need to check out the diameter and pickups when it gets here.
Worst case is I'm out $75 bucks.
EDIT: It looks like I have an extra rotor. The Gladius rotor will work, but it's pretty much the same. Not lighter or smaller. Only difference is the metal over the magnets on the Vstrom rotor. Gladius magnets are exposed. I'm leaving the stock rotor on.
D.T. is offline
post #45 of 92 Old 04-18-2013, 06:45 PM
Originally Posted by CollingsBob View Post
The best way to go faster is to use your brakes less...practice slow in,fast out..practice being smooth through the corners..
Also, late braking.
It took me years of off-road racing to learn that late braking is a huge difference maker in lap times. Once I stopped coasting downhills and coasting into turns, I got much faster.
Not really applicable to legal street riding, but I bet a lowly 650, if kept in the proper gear, and using good technique, would dust a lot of sportbike riders ona track.
DaisyCutter is offline
post #46 of 92 Old 04-23-2013, 02:38 AM
marcoma's Avatar
Motor swaps and rebuilds are all fine and dandy but are there any "free mods" to the performance of the bike? I've got several extra BHP out of my other bikes by reading the forums and doing the free mods they suggested - simple stuff like removing flapper valves for noise control, cutting a wire to fool the ECU into using a more aggressive fuel map, grinding 1/2" off a throttle stop to get full throttle, opening up the airbox, etc, etc
Bueller????
marcoma is offline
post #47 of 92 Old 07-04-2013, 05:02 PM Thread Starter
D.T.'s Avatar
Tried 2.5 gallons of 102 octane fuel today.
$7.75 a gallon, sure noticed a bit more get up and go.
I know I'll get the "waste of money" BS, which it is. But I bet $$$ that you get 2-3 hp out of the stuff.
D.T. is offline
post #48 of 92 Old 07-04-2013, 05:30 PM
I just can't imagine where the extra hp could come from, given that btu per gallon is the same. Spend more for a dyno comparison and we'll start to believe.
dkayak1 is offline
post #49 of 92 Old 07-04-2013, 05:44 PM
Thumbs up
, Where did you pick up the HP in a can Aviation Fuel,
Lots of racers out here use and love it as an alternative to C12 or C16,
Blair
post #50 of 92 Old 08-01-2013, 03:12 PM
helipilot1000's Avatar
check out the dyno charts from two brothers.
http://www.twobros.com/Cust_Service/...us_SO_dyno.pdf
http://www.twobros.com/Exhaust/Suzuk...jpg:fineprint: look where the power curve is. the DL flatten out. Much like the 1000 does. I removed the secondary's and tuned the pc3 usb to richen it up above 7000 rpm. It now runs like the SV1000. it just doesn't rev as far. as the sv1000 does. But wow it pulls.
When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return.
helipilot1000 is offline
Human Verification
