meter select switch function ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 02-06-2013, 11:04 PM Thread Starter
Rode my new bike round trip to work today (46 mi r/t) for the first time. Below freezing and noticed no freeze symbol nor thermometer.
Checked the manual, and the meter select switch is mentioned in two places: one to switch between the odometer, two trip meters, and display brightness. That's what pushing the switch this morning did.
The second place in the manual is to switch between the clock (displayed) and the ambient thermometer (not yet seen).
What I don't see is any mention of how to choose which function is being controlled by the switch.
Also, dealer apparently installed the heated grips improperly -- on the highest setting could barely tell any heat at all was being generated, when I expect (and according to the manual) they should be too hot to touch with the bare hand.
joesmoe3 is offline
post #2 of 2 Old 02-06-2013, 11:17 PM
Moderator++
The temperature/time display is cycled by holding the meter switch in for 4 seconds. The freeze warning should show up regardless of that selection below 38F and turn the temp display on when it first shows up.
greywolf is online now
Human Verification
