Clutch Safety Switch - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 01-09-2013, 11:04 AM Thread Starter
Just a warning for anyone trying to take the clutch safety switch off of their 2012. They put a lot of thread locker on the screw and there is no way to get a screwdriver to turn it before it strips the head out. I had to drill the head off and then use visegrips to get the screw out. I had a starting problem is why I was pulling it off. Funny thing is after I took the switch off it started working. What's up with that?
glastron is offline
post #2 of 19 Old 01-09-2013, 12:24 PM
randyo's Avatar
be aware that bypassing your clutch safety switch will affect your fuel map
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #3 of 19 Old 01-09-2013, 02:57 PM
Mr_McBride's Avatar
What does the clutch have to do with fuel mapping?
What's the thought process behind that decision?
-rodney
2012 G-Strom - White
Mr_McBride is offline
post #4 of 19 Old 01-09-2013, 04:24 PM
henerythe8th's Avatar
that little switch feeds data through the 'puter.
for an interesting history lesson use the advanced search and go to threads by maine-iac re: clutch switch
apparently before 2007 it was just a switch in the starter circuit, in 07 it went through the ECU
2011 MG Stelvio
henerythe8th is offline
post #5 of 19 Old 01-09-2013, 05:37 PM Thread Starter
Yes, it kicks the red f1 light on. I'm waiting on the replacement screw. It resets when you turn the key off and takes a few shift cycles to kick back on. Hopefully the part will be here tomorrow.
glastron is offline
post #6 of 19 Old 01-09-2013, 06:36 PM
Moderator++
I just checked all the FI error codes to make sure. There is no error code that will be activated by a clutch switch problem. If there is an FI light, it is caused by something else. Short the White/Red & Black/White wires together, the two top wires in the second pic, on the dealer mode plug near the tail with a paper clip or short piece of wire to read the error code when an FI light is on.
greywolf is online now
post #7 of 19 Old 01-10-2013, 06:59 AM Thread Starter
The FI light problem didn't come up until I had the clutch switch problem. Anything else that would be related that would kick the light on? I will do the code check later when I get some time. Thanks for the input.
glastron is offline
post #8 of 19 Old 01-10-2013, 09:09 AM
Moderator++
The switch affects the FI system settings so I guess it's possible. I've never heard of it happening before though. I don't think I've seen a report of an FI light on a Glee for anything yet.
post #9 of 19 Old 01-10-2013, 12:01 PM
Blackheart's Avatar
The clutch Not-so-safety switch is usually one of the things I eliminate first on a bike that I'm going to be riding in inhospitable terrain. I guess until this is figured out completely, and since I'm not planning on abusing this bike off-road all the time, I'll just wait a bit. I have no doubt that the people on this forum will have it sorted out completely before long!
Blackheart is offline
post #10 of 19 Old 01-11-2013, 07:10 AM Thread Starter
Ok, did the code check and it's C65. I also did an net search and found another item that points to the switch kicking the code on. Finding out what C65 fi code is?? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Havn't tried this link but it talks about someone that put aftermarket levers on and made the clutch safety switch not work properly. It was on a suzuki gsxr600. So apparently the clutch switch does confuse the computer and sets a code. Still waiting on the screw to remount the switch.
glastron is offline
Human Verification
