Stock Seat has a left "lean" to it now - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 12-26-2012, 12:30 PM Thread Starter
lordneeko's Avatar
This might only be my problem. I'm about 5'9 with barely a 30" inseam. Because of this I of course only use 1 foot at a stop, and typically I have to slide forward and to the left a bit to do so. So because of this, when I lift my foot, I probably don't always recenter myself properly. Now, it seems like the very best i try to center myself, I feel like the seat has my hips twisted down on the left side. Not sure if anyone else has noticed this.
2006 Vstrom 650
1999 Triumph Trophy 1200
2012 Vstrom 650 (current)
lordneeko is offline
post #2 of 5 Old 12-26-2012, 01:34 PM
It would take quite a bit of use to actually deform the foam that much I would think.
Pull your seat and check that all the black rubber bumper pads that hold the seat base off the frame are still in place. These are notorious for coming loose and could certainly cause the seat to lean slightly.
WERKS Quiet Ride windshields for 2012+ DL 650-transform your V strom. Nothing compares.
Have questions about the Quiet Ride or clutch in your DL or SV 1000? E-mail Terry info@werksparts.com
realshelby is offline
post #3 of 5 Old 12-26-2012, 01:57 PM
Blackheart's Avatar
...and I was afraid this was going to be a political post!
I'd also suspect that it's probably an underneath bumper out of position (or missing), or the front hooks aren't in correctly, or something along those lines.
Blackheart is offline
post #4 of 5 Old 12-27-2012, 09:25 AM
I would check to see if all rubber stops on the underside of the pan are still there. They have been known to fall off. It happened to me.
2012 Suzuki DL650AL2
1982 BMW R100RT
1985 Diamondback Ascent EX
boatin is offline
post #5 of 5 Old 12-27-2012, 10:17 AM
hunt1moore's Avatar
My bike was missing two the first time I removed the seat when I got it home.
PC-V, TRE, CR8EIX , ECM, K&N, RDL, PR4, PC-8, EB H4, WERKS, Madstad 22", 17/43 gearing, AdventureTech: Fork brace, shelf, mirror extenders, SpeedoDRD, wheel spacer, Head's-Up voltage monitor, Goldwing pegs, Sonic 1.1. Wolo Bad Boy.
hunt1moore is offline
Human Verification
