TEKA2 on DL650 L2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 12-17-2012, 10:43 AM Thread Starter
TEKA2 on DL650 L2
Hi all.... I have a TEKA2 Factory Pro and I would like to use it on a DL650 L2, but my TEKA 8 pin conector it does not match with 6 pin conector on L2, is there any adaptor or so for it ?
Another question , I need to check TPS on a bike like that, where is that conector in the bike ?
Thanks
SANDOSER is offline
post #2 of 5 Old 12-17-2012, 10:53 AM
Moderator++
The dealer mode connector for checking the TPS is at the rear under the cover on the left side below the seat. I wouldn't try changing the fuel map. It is very good stock.
greywolf is online now
post #3 of 5 Old 12-17-2012, 01:35 PM
D.T.'s Avatar
Teka, SFI Tuning procedures, Suzuki, Factory Pro
I was just looking around. DTC on the L2 is a white 6 pin connector. On the SV it has a black SDS connector.
I agree with GW, the stock map is pretty good.
2005 Suzuki SV1000R, 1985 Yamaha XT608N, 2012 Suzuki DL650AL2, over 25,000 miles already!
D.T. is offline
post #4 of 5 Old 12-17-2012, 04:39 PM Thread Starter
ok, I found it.
I did the clip bussines , but on the screen I canīt find -C00 and I change the fields with my left index and just ...... Odo, trip , and 0000.
......am I skipping something ?
SANDOSER is offline
post #5 of 5 Old 12-17-2012, 04:45 PM
Moderator++
Are you certain you are connecting the White/Red & Black/White wires with the jumper?
Human Verification
