Replace Ignition Cylinder? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 11-15-2012, 09:30 PM Thread Starter
So I tore down my front end to replace some parts damaged during a couple attempted thefts. My question is do I need to rekey the entire bike if the ignition lock requires replacement? My key still works but the little key hole flap that prevent the hole from filling with crud is damaged, but I believe I need to replace the entire assembly just to get that lil flapper.
Anybody done so that can fill me in?
crankinaway is offline
post #2 of 8 Old 11-15-2012, 11:56 PM
Probably yes to the rekeying.
I cut a flap of rubber sheet and put some velcro strip on it and the other gender on the steering head (under the bars), I ride enough in rain that my last DL started having lock problems.
Better waterproofing than stock anyway. Wouldn't work well on a pre-2012 model , but should be enough on these.
No pic, but it should be fairly obvious how to do it. If you need a photo, pm me.
Pete
PeteW is offline
post #3 of 8 Old 11-16-2012, 09:10 AM Thread Starter
That could work, but I think I want to have something a little more oem looking. Essential this damaged was cause within the first week of owning my bike so I am trying at the very least to restored it to the condition I rode out of the dealer.
post #4 of 8 Old 11-16-2012, 05:20 PM
nbsdave's Avatar
New switch is in order if you want to be original, can't see getting the switch apart to get the metal flap installed.
Then the seat lock will be an issue. Maybe you can get both keyed alike if you order from mother Suzuki.
nbsdave is offline
post #5 of 8 Old 11-16-2012, 05:28 PM Thread Starter
Well I have managed to take the lock right down to the tumblers and the dust cover is a seperate piece which of course is not available seperately.
I have tracked down a lock assembly from an 2009, any chance it would fit?
It appears to be the same dimensionally but I remember reading somewhere about the keys changing slighty for 2012.
post #6 of 8 Old 11-16-2012, 10:13 PM
Lock problems
I am in Vancouver and own a Locksmith Shop, I can help rekey a lock or help with any lock related issues.
email me at davidb@citiloc.com
Kiwi Canuck is offline
post #7 of 8 Old 11-16-2012, 11:17 PM
larolco's Avatar
Might also want to think about why you've had a "couple" attempted thefts in such a short time of ownership. Where do you park this thing? Why does someone feel it's a promising target?
Maybe some sort of visible wheel lock is in order?
DL1000K6
DRZ400SK17
larolco is offline
post #8 of 8 Old 11-17-2012, 12:23 AM Thread Starter
Chained to the wall with a Mcguard and disc locks, but they still wanted it! I have sinced moved and now have secure garage parking.
I have come up with an alternative. Purchase the lock assembly for the seat which is much cheaper and use the dust cover from that assembly. Appears to be the same size and if it don't work I am only out $60.
Human Verification
