Lowering the bike vs handling - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #21 of 24 Old 11-07-2012, 07:55 AM
Moderator++
The bars are just about at the limit anyway. More than about 21mm will allow the lower legs to crash into the triple clamps.
greywolf is online now
post #22 of 24 Old 11-07-2012, 01:50 PM
Lowering
2 inches is dangerous. 1-1/8" to 1-1/4" is the maximum. Your tire can hit the inner fender. With the rear lowered more than the front, the aerodynamics are worse than stock so front end lift at speed is even more of a factor. You may have been lucky so far but you're pushing the envelope.
As to the 3/4" front lowering on my bike, it's really 3/4" fork extension so isn't quite an actual 3/4".
What was the name of the rear lowering kit that u used. 3/4 inch seems ideal. Thanks. Phil
phil323 is offline
post #23 of 24 Old 11-07-2012, 02:35 PM
Moderator++
Lowering Links for the DL650 and DL1000!
post #24 of 24 Old 01-10-2016, 04:28 PM
ryandono's Avatar
Thinking About Reversing Lowering
I bought a Wee that was lowered. I am 6' 3", so height doesn't bother me. I can flatfoot a KLR. The Wee I bought has the Kouba V-Strom 2 links and lower forks. I was thinking about leaving it, but based on what I can gather, if I can have it higher, the Strom handles better. It for sure has an issue with the side stand not being stable. I've been using the center stand. I was going to modify the side stand, but after reading this post, I think I'll reverse the lowering for better handling. Why fight the Suzuki engineers?
Ryandono
2009 Suzuki V-Strom DL650 ABS
2006 Kawasaki Eliminator BN125 (20152016)
ryandono is offline
Tags
handling , lower , lowering , suspension
Human Verification
